Old 05-01-2004, 07:33 PM
stylzsignature stylzsignature is offline
Send a message via AIM to stylzsignature Send a message via Yahoo to stylzsignature
So tired of trying to find problem
I have a 1986 Iroc, there was a 305 in it. I had a 350 put in to it and since that...when I first start the car I have all the power in the world, but after I drive for a moment especially if it is hot out side, the car drives like a neon, total loss of power. Also oil pressure drops to red zone. note: I have replaced the thermostat, radiator, water pump, spit fire plugs wires and rotor. please help me!
Old 05-01-2004, 07:37 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: So tired of trying to find problem
well if your fuel pressure drops check your fuel pump or oil pick up, to do that you have to pull the oil pan
Old 05-01-2004, 07:39 PM
damn i said fuel press. wtf, i mean oil pressure and oil pump
Old 05-01-2004, 07:45 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
I have found really low oil pressure to be common in all the camaro's Ive owned..
I think RidgeRunner may have been correct in his mistake.. Check your fuel pressure when the engine is hot.. Check your air filter.. It could be real dirty.. Paper filters tend to swell up in the heat..
Is it TPI? TBI? carb?
Old 05-01-2004, 07:46 PM
DaMoNe6969's Avatar
Check your timing also...
Old 05-01-2004, 07:50 PM
well his loss of fuel pressure wouldnt cause oil psi to drop
Old 05-01-2004, 07:51 PM
DaMoNe6969's Avatar
Yeah I know, but low oil pressure is common in these engines.. It may not be related to his problem..
Old 05-01-2004, 07:52 PM
yea thats true, at idle mine would drop down to around 10, and when i got going it would rise to around 40
Old 05-01-2004, 07:56 PM
DaMoNe6969's Avatar
All my guages are canadian, so i never know what its at.. Damn metric system.. But I know in all the Camaro's ive owned, it wasnt unusual to see the OP needle in the low red..
Old 05-01-2004, 08:01 PM
thats funny, i bet that looks different
Old 05-01-2004, 08:04 PM
oo yea by the way, it proly is your fuel pump that happend to me at the track, i got half way down the track and had just shifted into second, and shifted into d right b4 the finish line, it was pathetic.... slowest time ive ever ran
Old 05-01-2004, 10:22 PM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
Re: Re: So tired of trying to find problem
oh not at all normal oil pressure is around 60. if its running low then the sensor may be bad (my 84 my buds 89, my new 97 and my dads 2000 camaros all run around 60 and the pressure changes between 40-60 depending on rpm and temp out side
Old 05-01-2004, 11:55 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
are we talking carb or EFI? if it's EFI did you change the prom?
like DaMoNe said check your timing, also check your egr.
