Old 05-01-2004, 05:03 PM
Powassan Powassan is offline
Angry 1974 350 Chevy small block
Okay, this engine has about 1 week before I go at it with a very large hammer. I took a 350 out of a 1974 Camaro and dropped it into my 1983 Pontiac Grand Prix. Ever since then, the engine runs like crap at an idle and often just shuts off, espicially when going from neutral or park to drive and reverse. It runs okay at higher rpms. I put the timing light on it and according to it, spark to #1 cyclinder is occuring about 50 degrees after TDC, when it should be around 4 degrees before. Everything points to timing, but I just cannot figure this thing out.
The heads have been machined, the crank is fine, there is a new camshaft, timing chain and gears, new lifters and rods, and I have tried different intake manifolds, and distributors but the ^&*#ing thing will not run right.
Old 05-03-2004, 02:20 PM
badguy in bowtie's Avatar
badguy in bowtie badguy in bowtie is offline
Send a message via Yahoo to badguy in bowtie
Re: 1974 350 Chevy small block
If you unplug the vaccum advance and block it at the carb at reset timing to 10 to 12 degrees before TDC at 600-800rpm idle in park it should run better.
Nothing but bowties in my drive way
86 Chevy 1/2 ton 2wd short wide bed, 350 slightly modified, 700r4, 3.73 gears
85 Monte Carlo SS, 350, 200r4, 3.73 gears
I have a new website for 73-87 Chevy trucks, come by and check it out,
http://bowtieguy.proboards33.com/index.cgi
Old 05-10-2004, 10:09 PM
Yep, I tried that, and I have become fed up with the engine so it iscoming out and I am working on adding a 5.7 liter GM 350 fuel injected engine. Its quite the project but it will be worth it.
