Old 05-01-2004, 01:35 PM
V-K V-K is offline
Send a message via AIM to V-K
Adjusting Valves
I've got this god aweful ticking that starts when the engine is getting warm, so I was thinking about adjusting the valves (I just put the motor in no to long ago)
What should I look for, and how do I know exactly when each cylinder is at TDC?
Old 05-01-2004, 01:56 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
additional info: http://www.quickhonda.net/valve.htm
both sources came from: http://www.quickhonda.net/index2.htm that is an excellent site to bookmark for further info!
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-01-2004, 02:29 PM
88ReX 88ReX is offline
So if you adjust your valves and the ticking doesn't go away then ! ?! !? ! I have this problem.
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 05-02-2004, 01:23 AM
BullShifter's Avatar
Re: Adjusting Valves
Then you have upper end damage or incorrectly adjusted valves. always adjust cold.
Old 05-02-2004, 02:45 AM
Yea I did adjust them when they were cold, they were still ticking right after I did the adjustment too. What exactly is "front end damage"?
Old 05-02-2004, 10:17 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Our injectors are pretty loud themselves too. They make a clicking noise when they open and close. So you may never really get rid of the noise.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-02-2004, 02:48 PM
Upper end damage is damaged/worn parts in your cylinder head. It could be anything from worn journals to bad bearing caps, rocker arms, valves, guides . . .basically anything that moves. For further cylinder head information - http://www.binghamtonlife.com/manual...alve_train.htm Before you going tearing stuff apart pin-point the noise using a stethascope(sp*?)
