Old 05-01-2004, 11:05 AM
Strt1189 Strt1189 is offline
Door Hinges
What do you guys use for making door hinges? Im thinking about using some plastic of a package.
Old 05-01-2004, 11:34 AM
freakray freakray is offline
AF Modelrater
Re: Door Hinges
http://www.scaledreams.com sells door hinge kits.
Alternatively, there is a tutorial on making door hinges here:
http://www.briansmodelcars.com/tutor...ID=1&CurPage=1
AF User Guidelines
Old 05-01-2004, 12:37 PM
I was giving a go on these little hinges (similar to your door) I got from my hobby shop. It's tricky buy it's worth a shot.
Things to watch out for are:
- How much your door can/can not swing.
- Door pivot.
- Make sure you have the door swings straight out, not sag down or up.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 05-01-2004, 01:04 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I use brass for all of my hinges. Works real well.
-Mike
Old 05-01-2004, 03:28 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: Door Hinges
right now, i'm using bits of sprue that i drill a hole for to insert brass rods bent into shape.
what i've noticed so far is that you have to shave down body work to a fine point so that the inside edge of the doors can swing free from and into the body.
...really badly worded but i'm sure someone understands me...
i got a little progress thread going on about my GT3 on which i've taken the doors off.
i've only just managed to get one side working smoothly so pics and new report will be up in a day or two.
AF's Guidelines
Read them.
Old 05-02-2004, 06:14 AM
UKSupraboy's Avatar
UKSupraboy UKSupraboy is offline
Hi,
I put instructions of the way I do it in this thread, Hinges
Maybe it will be of some help, maybe not, but it works for me OK.
Good luck
Richie
BSR (Sweden) A4 1.8T 225+hp 330Nm
