Old 05-01-2004, 11:01 AM
happy s-10 happy s-10 is offline
erratic fuel gauge
Anybody have problems with their fuel gauge jumping back and forth between full and empty erratically?
Mine will flip back and forth at various times when I'm driving, but it always reads full or empty and is never right.
I've followed the wires back looking for a ground, didn't see anything obvious. I also pulled the connector off at the tank and reconnected, with no luck.
Help?!?!
99 S-10 ZR2
Old 05-01-2004, 03:31 PM
hakogen's Avatar
hakogen hakogen is offline
is your MIL on?
Old 05-02-2004, 06:37 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: erratic fuel gauge
Help?!?!
99 S-10 ZR2
What is going on is that the level sensor has a bad spot in it and is causing the gauge to read erratically.
Replacing the level sensor will cure this problem.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-02-2004, 08:14 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
sounds like a bad sending unit..
Old 05-02-2004, 09:41 AM
About the comment about the MIL being on....I'm not familiar with that.
I'm assuming the level indicator is with the fuel pump? Is that right? Is this the same thing as the sending unit?
I've never messed with any of this stuff, so it's new to me.
Thanks for the replies
Old 05-02-2004, 11:03 AM
GMMerlin's Avatar
I know stuff
I wouldn't worry about the MIL..also known as the Service Engine Soon light.
The MIL will not illuminate for a faulty fuel level sensor.
The level sensor (aka sending unit) is located in the fuel tank with the pump.
GM WCT
PM Me for details
Old 05-08-2004, 12:10 PM
Re: Re: erratic fuel gauge
Can I just replace the sending unit then, or do I have to do the whole pump?
thx-chris
Old 05-08-2004, 12:28 PM
rlith's Avatar
you should be able to just change the sending unit...Pump is seperate
Old 05-09-2004, 08:47 PM
Yellow_X10 Yellow_X10 is offline
Check to see if your truck is under recall for this problem. I had a 2000 S10 Blazer that did the same thing. They fixed it as a warranty issue last year, but they said Chevy was supposed to do a recall on the S-10's for the same reason. It's a fuel relay problem. But just in case, here's the symptoms I had.... It said it was full most of the time and then would drop to below empty and the light would come on. If I rocked back and forth in the truck, it jumped back to full. I have since moved on to a newer truck but I still stand by my S-10s.
Old 05-11-2004, 01:32 PM
hakogen's Avatar
merlin, can you help with a little problem i ahve along the same lines? i ahve an 01, 2.2 2wd 5speed. and my mil comes on and the fault codes are p0178, p0179. thats fuel composition sensor circuit high/low input. can you translate this to a specific problem? it runs fine, its got abuot 75k hwy miles on it, replaced the clutch (didnt blow, making throwout bearing type racket) i keep up on the oil and lube stuff, and im a poor college kid. any help would be of great favor. thanks.
Old 05-22-2004, 12:08 AM
civic_104 civic_104 is offline
i have the same problem with my civic, my fuel indicator goes up and down a bit, but not from empty to full, and i ask around, it could be bad ground or could be faulty floating thing inside the fuel tank.
