Old 05-01-2004, 10:48 AM
bishop_944 bishop_944 is offline
Question 94 del sol si v.s. vtech
How can you tell if a del sol is si or vtech if all badgers are removed?
Old 05-01-2004, 12:23 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: 94 del sol si v.s. vtech
It is called VTEC , use it!
You can tell if it is a Si or VTEC model by looking at the motor, if it has a DOHC VTEC motor then it is a VTEC model and if it has a SOHC VTEC motor in it then it is a si. Also I have heard that the VTEC model did not come in some colors such as white but can't remember if there are any other colors that it did not come in. There are probably more things as well, try checking the FAQ at the top of this forum.
Old 05-02-2004, 09:47 PM
s2Ksol s2Ksol is offline
Check for the stamped engine code on the engine block. If it says b16a2 or 3 then it's the VTEC model, unless a swap has been done. The Si model is a d16 engine. Also check the redline in the dash. The VTEC model redlines around 8200. The Si redlines around 7200. Check the VIN number. VTEC models start with JHM.
Old 05-03-2004, 01:04 AM
b16a3sol b16a3sol is offline
tire size is also another giveaway. s - 175's, si - 185's, vtec - 195's
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 05-04-2004, 03:48 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
or you could just do it the easy way and look at the valve cover..if it says DOHC then well its a dohc vtec , if it just has VTEC accross it then its an Si, if it has nothing accross it but a silver valve cover then its an s
Old 05-04-2004, 05:25 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
If you're looking from the exterior, only ways I know to tell if it's a VTEC would be if it had the B16 from the factory in it. The giveaway would be the rear sway bar, wider tires, bigger front rotors, and if it was Isle Green, Cypress Green, Milano Red, or Granada Black. VTEC's didn't come in any other colors in the US.
'96 - '97 Si's were also Cypress Green though, and if a motor swap was done, they could be missing the rear sway bar. Best sure fire way to tell is to lift the hood and get a look at the motor.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 05-05-2004, 01:07 PM
or write down the VIN number and call it in to your local honda dealer
