Old 05-01-2004, 08:04 AM
khopson khopson is offline
2004 F150 acceleration problem - HELP
I have a 2004 F150 FX4 with a 5.4 and 3.73 rear end. When I hit the gas, there is about a .5 second delay before she starts going. WHen it does, it seems to stutter a bit then go. When driving and hitting the accelerator to speed up, the same thing, a delay and then an unimpressive increase in power. The dealer says it is normal due to the "drive by wire" gas peddal. I drove the exact same model (but a different one) at the dealer and it was totally more powerful that mine. This is what I expected the 5.4 to feel like. Not the dog that mine seems to be (I swear it feel like a V6). Any ideas out there as to what the problem might be?
Old 05-01-2004, 11:55 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: 2004 F150 acceleration problem - HELP
try changing the fuel filter and run some sea foam through it. It is still under the 36/3 warrenty? Try the filter and the injector cleaner and go from there. Are you getting normal gas milage?
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 05-02-2004, 09:43 AM
Re: Re: 2004 F150 acceleration problem - HELP
Yeah it is still under the 3/36, but the dealers don't like to spend a lot of time on warranty work... The verhicle only has 5K miles on it. Could the filter be bad already?
Old 12-14-2004, 05:22 AM
venture1996 venture1996 is offline
2004 150 Acceleration
My 2004 150 5.4 has the same problem. Dealer blames drive by wire "improvement". Also encountered a rough idle problem at 350 miles, dealer said it could not be duplicated. The transmission also seems to not know what to do when you try to pass. Defective tires, 2 bad windshields, damaged trim due to previous reference, rough idle, engine stumbles, 11 mpg. Good thing I didn't spend $4000.00 less on the Dodge. Lastly, I have the payload package with 7 lug axles, no aftermarket stuff available.
Old 12-14-2004, 01:58 PM
ModMech's Avatar
ModMech ModMech is offline
There are few things in play here.
First, ditch the fuel filter and sea-foam ideas, they are TOTALLY pointless on a new vehicle.
Now, the engineers (NVH) had certain things programmed into the drive-by-wire software to prevent excessive driveline vibrations and clunks upon hard acceleration. This changes with gear ratio, wheelbase (6', 8' beds, standard cab, Super Cab and Super Crew) and also with 4x2 vs 4x4. So, when you say you drove the "same" truck, EXACLTY how identicle was it REALLY?
Also, the traction control system (torque limiting) will prevent excessive acceleration (will absolutely PREVENT wheel spin on dry pavement... as in NO burnouts). This management will often feel like a mis or studder, and slow acceleration.
This all about NVH and "Big Brother" (Ford) controlling and monitoring EVERY aspect of how YOU DRIVE.
Old 12-14-2004, 03:08 PM
WickedNYCowboy's Avatar
WickedNYCowboy WickedNYCowboy is offline
Send a message via AIM to WickedNYCowboy Send a message via Yahoo to WickedNYCowboy
Its the cruddy drive by wire. Dodge had the same problem with the hemi when it was first introduced. Well the .5 or delay atleast.
Evan
Support your local volunteer fire department
My Rides:
2003 Ford F-350 Long Horn Hauler
Others:
1999 Toyota Camry LE V6-Dad
2004 Chevy Tahoe Z71-Sister
2004 Toyota Camry LE V6-Mom
