Old 04-30-2004, 10:36 PM
Dr Juice Dr Juice is offline
Send a message via AIM to Dr Juice Send a message via MSN to Dr Juice
Why am I running rich
Would a aftermarker intake and exhuast cause motor to run rich on a 94 civic LX? If that couldnt be a reason, what could.
Old 04-30-2004, 10:54 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Why am I running rich
How rich are you running? Weak igntion, bad sparkplugs, bad sparkplug wires, dirty fuel injectors, bad O2 sensor etc etc alot can cause the car to run rich. What else have you done to the car? When was the last time you did a tune up, including changing the distributor cap and rotor along with the plugs.
Old 05-01-2004, 07:54 AM
plugs and wires are okay, cap rotor, not sure, anything ealts not sure. Im running 2.25 inch straight pipe tubing with resonator from cat back, no muffler. The intake and exhuast are the only mods i have to motor. Can tell its running rich cause it blows black smoke everywhere. Only does it around 4000+ RPM
Old 05-01-2004, 03:29 PM
Knowledgeb20 Knowledgeb20 is offline
if its only doing it at 4000 rpms id say its your throttle position sensor
Old 05-01-2004, 03:38 PM
yes its more than likely your TPS sensor , but I would check the PCM for codes !!!!!!!
Old 05-01-2004, 03:41 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
How do you know your running rich, do you have a wideband o2 hooked up?
Old 05-02-2004, 11:11 AM
Um lots of black smoke, could be running rich all the time but just not visable. How would i check the TPS if its shot
Old 05-02-2004, 08:17 PM
Other thing i forgot to mention, could it be a vacume leak. There is a hard peice of plastic on the end of the hose that goes in the intake, that sits half way in cuase it isnt long enogh to reach to the valve cover with the house all the way in.
Checked for codes today, nothing, im ganna fix the exhuast manifold leak tomarrow and then test O2 senser alot with map and TPS
Old 05-03-2004, 06:08 PM
sorry for posting again, but how about a crappy cat, it looks pritty beat.
Checked for codes none, fixed my small exhuast manfold leak, seemed to help cut that black smoke back.
