Old 04-30-2004, 09:39 PM
EvoChris EvoChris is offline
Help with JL amp settings
I'm trying to figure out how to set the Input Sensitivity Level on my 250/1. The exact words for what I need are
A Digital AC voltmeter, which I already have.
A CD with a sine-wave test tone recorded at 0 db reference level in the frequency range to be amplified(ex. 50 Hz for a subwoofer amplifier. 1kHz for a midrange application). Do not use attenuated test tones (-10 db, -20 db, etc).
I have no idea what they are talking about with this sine-wave tone stuff. It says to play a track with an appropriate sine wave (within the frequency range to be amplified)
Can anyone explain this to me so that I can see if I can set this right.
Old 04-30-2004, 10:12 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Help with JL amp settings
A sine wave is just a pure tone at a certain frequency, much like plucking a single string on a guitar or playing a note on a flute or any other musical instrument. ~20-80hz is the range that subwoofers play, midranges play ~80-2500, and tweeters play ~2500-20,000. Since this is a sub amp, you want to use a frequency that the sub will play, so anywhere between 20-80 would work. They recommend 50, which is right in the middle of the range.
Now you just need to find an mp3 or a wav of a 50hz sine wave that you can burn to a cd, so you can use it to set your gain.
http://www.ihearyou.com/testtones/
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-02-2004, 10:14 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
just one note ..... it is critical that the tone you record is set to 100% digital max volume - meaning at the top of the wave it is recorded as all 1's. If it's not, the levels will be off.
