Old 04-30-2004, 07:52 PM
JS567 JS567 is offline
cpi 95 blazer
I just changed the cpi unit in my 95 blazer but i did not change the fuel lines going into the cpi itself. Before closing it up I turned the key forward to pressurize the system and it did not leak. I changed the O rings to the injecter. Does it matter that i did not change these fuel lines??
Old 04-30-2004, 10:01 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: cpi 95 blazer
I recommend changing the lines do to the fact that they are plastic and will eventually leak.
A failure of the pressure line can fill the crankcase with gas..which can lead to some exciting results (seen that first hand...still looking for parts of that oil pan )
I leave that decision to you.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-01-2004, 04:16 PM
Re: cpi 95 blazer
For now I am going to leave it, seems to be running good. starts better, runs better. if the problem starts again then i will change the lines. Is it possible that the line could be leaking even though i checked it by just just turning the key to pressurize the lines before I closed it up?
Old 05-01-2004, 04:17 PM
Re: cpi 95 blazer
Also how do I get those lines out if i wanted to change them?
Old 05-02-2004, 09:00 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: cpi 95 blazer
Yes, they could still leak, they get brittle with age and should be replaced with the CPI after 100k.. To remove them, on the outside of the lower intake where the lines come in is a retainer plate. Use a t25 torx bit to remove, disconnect the fuel lines, (depressurize system first) Then they slide out...Installation is reverse...
