Old 04-30-2004, 05:19 PM
shell-bell shell-bell is offline
Question taking out speaker
I have a 1999 camaro and my middle speaker on the drivers side is blown out. I just need information how to properly disconnect the wires from the speaker because i dont want to cut them. Any info would do a lot of help!
Thank you!
Old 04-30-2004, 05:57 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: taking out speaker
the middle speaker on the driver side??? you mean in the door? or the sail panel? i think thats what your talking about. the one right behind your head??? the wiring should have a plug on it, with a single tab release, just press the tab down and pull the connector off. im a chevy tech, so if you need help, or instructions on gettin in there just gimmi a holler, and ill do what i can.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-30-2004, 06:04 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
to put in a new one, aftermarket, i think you need to buy a GM kit that has the adapter plug.
Old 04-30-2004, 06:05 PM
89IROC&RS's Avatar
good point, replacing with OEM equipment or aftermarket?????
Old 04-30-2004, 11:06 PM
GoBears's Avatar
GoBears GoBears is offline
If its a monsoon system...I am almost positive that speaker is a small dvc subwoofer. That speaker IS cross'd to receive only low frequencies.
Old 05-01-2004, 02:07 AM
It was the same way in my '96 Delco Bose, only lows from both those speakers.
Old 05-01-2004, 07:30 PM
89IROC&RS's Avatar
wasnt that one in the trunk????? i thought they had 4in in the doors, 4in in the sails, and the subs in the back... and a set of 4in in the cargo area. so the middle would be the sail panel right????
Old 05-02-2004, 01:11 AM
My delco bose had 6.5" all around, the rear two dedicated to Bass, while the one in the trunk sem to be a loud all around speaker, also 6.5".
Old 05-02-2004, 07:50 AM
GoBears's Avatar
I have a 99 and the replacement/aftermarket speakers are as follows. Front door is 6 3/4", sail panel 6 3/4" and finally the hatch area speakers are 4". In a monsoon setup the speakers are also supposedly using crossovers along with factory amplification. The front door and hatch area speakers are to receive mid and highs and the sail panel speakers are used for lows.
