Old 04-30-2004, 06:07 PM
CORE402's Avatar
CORE402 CORE402 is offline
Post Drive Train question
I have a question on how well will a stock th350 backed with a stock 8.5" corporate 10 bolt take abuse from a 350sbc putting out around 400 hp. I do plan on taking it to the strip occasionally after I put in my aftermarket gears (3.73:1) and posi (Auburn, Cone style) Thanks.
Old 04-30-2004, 06:15 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
the th350 is a pretty good tranny, i think you'll be fine there. i've heard the 7.5 rearend is good to about 400hp so if you've got an 8.5 i think ur good there too.
Old 04-30-2004, 06:17 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Drive Train question
the turbo350 was a strong, reliable tranny.. But at 400hp, ide be lookin to build that th350 up.. It'l hold it.. but for how long?
Old 04-30-2004, 06:55 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
it will handle it without a sweat.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-30-2004, 08:59 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
yeah i would say your probably fine. the only way you might not be is if you run slicks and have alot of traction. if you launch hard then there is a pretty good chane you will break something. but i run close to what your talking about except my trany has had a little work and i have the original 8.2 rear. but like i said unless you launch really hard im sure you will be fine.
Old 04-30-2004, 09:52 PM
CORE402's Avatar
Thanks guys. I do plan on going over my TH350 in the future. At that time I plan on putting some extra horses into my motor. I plan on using something similar to CHPs impersonator motor (425hp with 528ftlbs of torque). Do you think with new rear end gears, posi, and a rebuilt th350 that I would still be in the clear? Thanks again
Old 04-30-2004, 10:45 PM
89IROC&RS's Avatar
well, lemmi put it this way, the TH350 is one of the most popular drag racing trannies around, second to the TH400, at least in the GM lineup, i guess the powerglide is actually first but whatever. the 8.2 is pretty strong, should handle that powerlevel if you dont do alot of neutral drops, i think if you put a B&M kit in the trans, and build the rear proporly, with a stud girdle, youll be fine.
