Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-30-2004, 03:18 PM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
Turbo engine management
Does anybody know any good engine management systems for a turbo car on an OBD-II. I know Hondata will only work on OBD-I and the swap i asume is a pain. I think the A'pexi will also only work on OBD-I. Does the GReddy E-manage, cuz my cousin has it on his IS300. Im not too fond of GReddy though. If anyone has any ideas on what to do, or explanation of the swap thatd be great cuz i like the hondata.
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 04-30-2004, 03:48 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
Re: Turbo engine management
Aem Ems
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 04-30-2004, 05:57 PM
Ya that would be nice but outta my price range. I shoulda noted that that one is out
FOR SALE
Old 04-30-2004, 06:29 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
The obd2 to obd1 conversion is not that complicated. There are aftermarket conversion harnesses that you can buy that allows you to basically plug your obd2 harness into a obd1 ecu. I would do with the hondata for best feature for the price. The emanage is a glorified Apexi AFC.
Old 04-30-2004, 10:04 PM
YellowITR479 YellowITR479 is offline
Heard bad things about the Hondata & E-Manage. Go with the EMS, worth the $$$
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 04-30-2004, 10:22 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: Turbo engine management
What bad things have you heard about Hondata? I have never heard one bad thing about it.
Old 04-30-2004, 10:37 PM
None in general, heard from 2 people that bought them and sold them like a month later and got the EMS. I was looking into a hondata but was steered away from it. How much does it cost by the way?
Old 04-30-2004, 10:51 PM
whtteg's Avatar
It costs about $400ish for the s200 with boost option.
Hearing from 2 people who bought it and then sold it a month later does not reflect the products quality, there might have been more reasons behind them selling it. But like I said I have never heard one bad thing about hondata, and i know alot of people here in GA that are running it, and are as happy as they can be.
Old 04-30-2004, 11:14 PM
I also have never heard of any problems with hondata. That is what I plan on running in my racecar when I finish it. The AEM EMS is by far one of the best stand-alones I have ever seen and is worth the price. The downfalls to it are that it is not very user friendly and competent AEM tuners are hard to come by.
Old 05-02-2004, 11:58 PM
TEAM KLR's Avatar
TEAM KLR TEAM KLR is offline
Send a message via AIM to TEAM KLR
deffinatley go with the hondata, your dealer should be able to set up with a full system w/ injectors and tuned for just under $1000 to $1500 depending on just what options you wanted and still get the options that you need for the lower price. They are a breeze to tune also and support a pretty effective autotune function used in conjunction with a wideband system, your dealer should also have one of those. check out hondata's website
www.hondata.com and look into the s200 section.
Old 05-03-2004, 02:02 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
for 1000 to 1500 he could just get the AEM ! You can get and tune a hondata for less ! both are great systems
Old 05-03-2004, 03:19 PM
TEAM KLR's Avatar
They are both good, but he would still have to purchase injectors and get it tuned. What I listed included everything and labor for the install, set up, and tune.
Everyone has a prefference and a different experience, like said before, they are both good systems, bottom line is you can get more for less with the hondata way. If you do have the extra time and money to invest into an AEM system go for it! The AEM does have a better autotune function and can yeild more options in the end but for any normal person that has hp goals up to 500-600hp atw the hondata is gold!
Old 05-03-2004, 07:39 PM
boosted331 boosted331 is offline
Re: Re: Re: Turbo engine management
Don't mistake the AEM's auto fuel correction for automated tuning, we don't want anyone to get it in their head that if they plug the AEM in and go their car will run like gravy. Basically what you do is get a solid tune going, then you set a target AFR for cells in the AEM, make a pass through those cells, and then the AEM will adjust the fuel trim till the AFR is spot on to perfectly smooth out the car.
Old 05-03-2004, 11:03 PM
TEAM KLR's Avatar
Yea, boosted331, I guess I should have made that alittle clearer. Good post. The Hondata system works in the same way, it works well for partial tuning, after you do a "autotune" pass, you "interpolate" the section you just tuned to smooth out the peaks and dips and then set that as the "new base". I would recomend doing all of the WOT tuning manually. I just feel better about my own active corrections than I do about the computer doing them for me.
Does the AEM autotune function work will for WOT tuning? Have not had any experience with that function on the AEM..
Old 05-04-2004, 03:07 PM
i havent either, id be interested in knowing as well...considering my build is almost complete and i am going to be in need of ECU selection here real soon
