Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 04-30-2004, 03:21 PM
SupeDuke2003 SupeDuke2003 is offline
Satellite Radio for 3 series? Where to get it installed? What type?
Does anyone know if you can get satellite radio installed on a 2003 3- series? Does only Sirus work with BMWs? Do I have to get it installed through BMW or can I do it through some place like Circuit City, etc? BMW was going to charge $299 (receiver), $125 Roof Antenna, $75 bracket, and probably $100 for installation....bringing the total to around $600....can this not be done cheaper anywhere else?
Old 05-02-2004, 07:34 PM
AUTOSTYLEINC AUTOSTYLEINC is offline
Send a message via AIM to AUTOSTYLEINC
Re: Satellite Radio for 3 series? Where to get it installed? What type?
you can get your self an aftermarket xm or sirius system for alot less. On avg of 250 installed for a complete system. It really just depends on how you want to integrate it into the system.
Old 05-03-2004, 01:21 PM
Re: Re: Satellite Radio for 3 series? Where to get it installed? What type?
Thanks for your help...What are the options for integration? Also, do I have to get a roof-mounted "shark fin" setup or a trunk-mounted one?
Old 05-03-2004, 05:33 PM
Well if you want factory integration you can get the following
SoundGate PIOBMW1
Pioneer GEXP910XM
Terk XMirco
Ai XM1DAS
and thats it. The Soundgate module uses your stock radio ( if its a dsp one you require an additional part ) and it plugs directly into it and allows it to control the pioneer xm module. It uses the factory radio for everything and allows the direct audio in. The screen on your stock radio dispalys the info etc. The pioneer GEXP910XM is the xm module. The antenna is TINY. 33mm x 35mm x 12mm and the Ai module is like a splitter/combiner. The pioneer module has 2 antenna inputs where as the Terk antenna is a single cable. That is your best bet if you want the best sound and COMPLETE integration into your factory unit. You need to find a more of a specialist type shop since your circuit city andbest buys etc dont carry these type of products.
