Old 04-30-2004, 02:09 PM
mike_kirchner mike_kirchner is offline
1995 Gramd Am 2.3l Quad 4 DOHC WONT START AT TIMES
I was wondering if anyone would be able to tell me why my grand am will not start sometimes. The car runs great when it wants to but at times you will go out to start it and it just cranks over no firing. If you leave and come back maybe 30 minutes to an hour later it will start right up. When it does start it runs kind of poor to begin with (you push the gas and it kind of dies down and goes nowhere) this last for about 10 seconds then it is fine. I have checked the ignition, coils, coil housing, plugs I am stumped. Someone told me that it is possible that the computer has gone bad. I just want some more opinions before I spend 100 bucks on a computer.
Old 06-01-2004, 10:06 PM
trkmike trkmike is offline
Re: 1995 Gramd Am 2.3l Quad 4 DOHC WONT START AT TIMES
my 94 has a ground wire under the pass. seat that came loose the car would crank but not run.bad place for a ground wire?? mine runs fine now
Old 06-04-2004, 03:39 AM
94greenbean 94greenbean is offline
Send a message via MSN to 94greenbean
my 94 grand am se does the same thing, its like the car is not all the way in park or something because it will not turn over, you turn the key and absolutely nothing will happen, 20 - 30 minutes later it will start up, but be kinda sluggish, then it will run fine. i have never figured out why
Old 10-12-2004, 11:39 PM
vinzul vinzul is offline
thats probly the N- safty switch i went trew tons of other things befor finding out that it was that
but running slugish should have nothing to do with it
Old 10-13-2004, 06:42 PM
tmwr2006 tmwr2006 is offline
Its your spark plugs, mine was hesitant on start and sluggish when start driving because my car was starting and moving on 3 cylenders until I got going then then the forth cyl. kicked in and away I went. SPARK PLUGS! buy good ones!
Old 10-14-2004, 04:27 PM
yeah maybe thats why its slugish
but thats not why its not turning over
i bet when you turn the key every thing comes on
but the car wont ingage the starter you wont even here the stater turn then you wait and it might work later
well if thats what its doing try this when the car wont start try putting the the shift nob threw all the grears then try to start if that dont work
put the car in N then roll it about a foot dont hit the break then trow it in park as soon as it feels like you hit the break hard turn the key it should start right up if it dose its the N safty switch
