Old 04-30-2004, 03:28 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Tranny grind found a good fix
Ok So I did the z6 engine swap about 4 weeks ago and I used my old si tranny. It allways grinded going into second gear so I thought I would use 20 wt. synthic motor oil. Well it helped a little. I found out that I busted the seal on the passangers side of the car in the tranny and I went to honda to get another one. I was talking to one of my buds in the service bay and he told me to use the honda MT oil at 7.56 a quart if it did not work he would give me the money I paid for it. So getting the seal I got honda MT oil. Tonight I installed the seal and drained the tranny for an hour, then refilled with 2 quarts. I put it all back together and drove it holly crap no more grind in second. I drove for about 3 miles before I tried to shift hard. No grinds what so ever even with the short shifter in the car. Honda did something to that oil to make it work right.
Also never put auto tranny fluid in to your tranny NO MATTER WHAT FOCKERS SAY. It eats up the coating on the gears and also mess up the bearings. I have a DX tranny that is bad after 6,000 miles because the fock that installed it put in auto fluid in. It is a factory DX tranny that was bought about 8 months ago from honda. It locks up the diff when trying to turn.
Hope this helps somebody.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 04-30-2004, 07:20 AM
SiZ's Avatar
SiZ SiZ is offline
Mine grinds in EVERY gear.. What can I do?
"The nympho of info, I'm fuckin' what ya heard"
Old 04-30-2004, 08:59 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: Tranny grind found a good fix
Rebuilding or replacing is probably your only option if you grind in every gear! I think most grinds are a result of physical wear on the actual gears, which really is irreversible. I would say that the Honda MT fluid is probably making things run smoother, but probably only masking, not fixing the grind.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 04-30-2004, 09:05 AM
SiZ's Avatar
SiZ SiZ is offline
I know this.. I was just venting.
I hope it just lasts a year or so so I can afford an ITR tranny.
Old 04-30-2004, 10:36 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
I was told to never put Auto tranny fluid, but motor oil. Some say gear oil, but NEVER auto tranny fluid. Another good product thats out there is LUCAS transmission fix. They also make an oil, fuel injector, and power steering product. It seems to have saved alot of people money w/ tranny problems
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 04-30-2004, 11:40 AM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
Check out GM Synchromesh (made by Penzoil). Check out http://honda-tech.com/zerothread?id=549469 for proof.
DOHC ZC 89 DX HATCH
Old 04-30-2004, 12:07 PM
88ReX 88ReX is offline
Honda MTL, Gm Syncromesh, and Redline MTL, all good products that will help butter up that transmission!
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
