Old 04-29-2004, 10:59 PM
taxman82 taxman82 is offline
Brake Noise
Hello! I have found the forum very informative for some problems with my 99 Silverado. This is my first post so stick with me. I replaced the front rotors, got the rears turned, and put new NAPA semi metallic pads front and back. Everything was fine for about a week then they started squealing after about 2 miles when the brake is applied at varied amounts of pressure. This has me stumped, I have double checked my work and it all looks fine. Any help is appreciated.
Old 04-30-2004, 03:48 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Brake Noise
you could a set of gm pads, or try putting some Brake Quiet on the caliper side of the pads sometimes it works.
Old 05-03-2004, 11:02 AM
Butch66 Butch66 is offline
I've got the same problem. I replaced all 4 rotors and pads with semi-metalic. I order ceramic pads for the back but when I picked them up they said they didn't make them. So I took what they had. I should have went somewhere else and got ceramic. My back brakes are squealing real bad. I heard you don,t get that with ceramic?
Old 05-03-2004, 11:07 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Brake Noise
Mine did this, and I had to remove the pads, roughen up the surface that contacts the rotor, sprayed a libral coat of brake quiet on them, cleaned the rotor w/brake cleaner, and re-installed it all. No more noise.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
