Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 04-29-2004, 08:11 PM
Rattling noise coming from cat
About a week ago I noticed that when my car is idleing at about 1500 RPMs when I first start it up, the catalytic converter makes a moderately loud vibrating noise. The car also does it around 3000 RPM's. Anyone know what the problem is? I think its either clogged or loose, but I have no idea. Thanks in advance.
Old 05-09-2004, 12:01 AM
dlinvill dlinvill is offline
Are you sure it's internal noise? The heatshield are just screwed on and could easily get loose enough to rattle. Also check where the exhaust bolts onto the tranny hanger. It doesn't seem like anything would get stuck in your exhaust near the cat without passing through the turbo (and making a big mess). The cat can break up but that would be very rare.
Old 05-09-2004, 12:03 AM
Sorry I was thinking WRX, i guess in the RS you might have something make it out the engine and get stuck. You could always unbolt that section of the exhaust and see if anything comes out.
Old 05-09-2004, 06:38 AM
ragnarok720 ragnarok720 is offline
Re: Rattling noise coming from cat
Ive heard of cats breaking up, rare but it does happen. Did you try to gut the cats by chance ever? Sometimes people dont get everything out and it rattles around but im not sure if it will make the noise you discribe. Might want to check your exhaust hangers and the bolts alongth cats as well as maybe checking the gaskets. Loose exhaust makes a lot of noise as ive found out.
Old 05-09-2004, 10:12 AM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
yeah. I'd check all the hangers and everything. I've had a rattle that was somewhat like you're describing when I had my dakota. I went under it and tightened all of the bolts and everything and it was gone. If that doesn't help, it might be time to get a new Cat. (Note: by national law, these are supposed to be garenteed for 80,000 miles I believe)
Old 05-10-2004, 07:41 AM
freakray freakray is offline
AF Modelrater
There is a heat shield on the cat, have it checked or check it.
We had the same happen on our '01 Forester.
AF User Guidelines
Old 05-12-2004, 07:40 PM
Re: Re: Rattling noise coming from cat
I took it in, and it was indeed the heat shield. He just removed it. 30 dollars! I could've done it myself if I knew in advance.
Old 05-12-2004, 08:54 PM
AF Modelrater
Dang!
Calkins Subaru charged us $7 to re-fix the heat shield correctly.
It's amazing how some dealerships are in it for the money while others are customer oriented.
AF User Guidelines
Old 05-14-2004, 11:16 AM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
Customer-oriented dealerships? I thought only Saturn had those... I've never been to a non-Saturn dealership that was really both friendly and helpful at the same time (a couple that were one or the other... but most were neither). The Mitsubishi dealership I went to last week (needed a part for my friend's GTO) acted like they couldn't even be bothered to acknowledge my presence, much less do their job. I haven't had too much experience with Subaru service, though, so I guess I shouldn't start talking yet.
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
