Old 04-29-2004, 09:03 PM
Ryanj33 Ryanj33 is offline
Ford Keys or Torsion bar crank?
Are Ford Keys or cranking the torsion bars better?
Old 04-30-2004, 08:35 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Ford Keys or Torsion bar crank?
Either way, your cranking the torsion bars a little. The ford keys have a slightly different index where the bar goes into the key..which turns the bar more...
I dunno why, but on my truck, the driver side bar is cranked all the way, and the passenger side, you can see half of the bolt. I'm getting some Ford keys to level mine out. At like $40, you cant loose ( I don't think).
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-30-2004, 11:00 AM
Phix_06 Phix_06 is offline
I'll be scanning pictures of my truck this weekend, I have the ford keys in and it raised the front end up 3inches and like J said they were only $52
Old 04-30-2004, 12:59 PM
Will the keys take more pressure off the truck then just cranking the bars?
Old 04-30-2004, 02:06 PM
jeverett's Avatar
They are supposeed to keep the suspension pretty close to the factory operating range, so I assume that it will take some pressure off of it.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-30-2004, 02:59 PM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
that answers my questions about those ford keys, what are the part#s
when u put them in is it a weekend job or a couple hrs or????
Old 04-30-2004, 08:36 PM
So you think the Ford keys would be better then just cranking the torsion bars?
Old 05-01-2004, 11:14 AM
jeverett's Avatar
The Ford part number is .... XL3Z5B328CA. You can get them at any dealer, or at http://www.fordpartsonline.com . I have found one of the most complete forum threads concering this install. According to that thread, it only takes a couple of hours. The link to that thread is http://www.fullsizechevy.com/forum/s...threadid=65871 (Dialup usere beware..this is a very long load with hi-res pictures.) Maybe this will answer any of your questions that I'm too stupid to answer
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-04-2004, 02:53 PM
TXAGG05 TXAGG05 is offline
...as Jeverett said, the ford keys just have a different index. With the ford keys cranked until your truck sits the same as your factory keys cranked all the way, you will still have as much pressure on your torsion bars as if your factory keys were cranked all the way. The difference is, because they are indexed, you can crank them further than the factory keys. So basically for the same amount of height, you get the same amount of tension on the bars. The IFS front end relies on the twist of the torsion bars, so the higher you go, the more twist you're putting on the bars.
Jeb
Old 05-05-2004, 12:19 AM
AlaskanZ71 AlaskanZ71 is offline
Send a message via Yahoo to AlaskanZ71
Easy job!
Yea ok so I went ahead and gave the bolts some twists and I agree with some others with the same deal about my drivers side being higher then my passengers side with less bolt remaining. O well I am too waiting on my local Fairbanks Alaska Dealer to get my Keys in and i will be turning mine up even more. But i have been warned that others with the same setup have experienced the bars exploding while offroading or in heavy Alaskan snow!!! The local shop i go to said that the keys are an easy way but there has been one case he knows of were the guys passenger bar just destroyed itself and the whole side of the truck just slammed down into the mudd?? O well, so anyway worth the chance!
2000 Silverado Z71 X-Cab
33" Mudd Rovers
Mudd Packed Fenders
Fully Tightened Torsion Bars
Aggressive Army Owner
Old 05-05-2004, 09:50 AM
jeverett's Avatar
I'm willing to take that chance myself...I'm tired of looking like my front end is scraping the ground.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-05-2004, 11:39 AM
i just want the freakin ford keys
