Old 04-29-2004, 06:48 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Car wont idle when venting to atmosphere
How you fix this problem, and also runs weired at rpm between 2000-3000 but runs sweet when your to the floor lol. I can vent normal but sounds so much cooler to atmosphere lol
Thanx eric
Old 04-29-2004, 06:53 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Car wont idle when venting to atmosphere
Try MAFt or a VPC. Oh yeah, or you could stop making your car into a whistle and save 400 bucks for the MAFt or 1200 bucks for the VPC. There's no way to vent cheaply.
Old 04-29-2004, 07:30 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
joe hit it right on the head, just get a MAF translator
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-29-2004, 08:24 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
i can vent mine without stalling or anything [runs rich between shifts] but i have a bunch of other mods too. check my car at the link in the bottom of the sig for my mods.
to vent it properly your only options are the VPC and MAFt.
Old 04-29-2004, 08:45 PM
JoeWagon's Avatar
Banned
I could manage venting if I tried, but I drive 3+ hours every day, so being that there is no benefit, I didn't look into it.
Old 04-30-2004, 12:05 PM
boostedinaz boostedinaz is offline
Send a message via AIM to boostedinaz
Venting=Ghey. Unless you have a MAFT or VPC then you car will run like shit. Thats the only way it works. You could buy 500.00 or more in parts to do it, or you could just hook it up the way it should be for free and have a good running car.
Michael
Old 04-30-2004, 03:28 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
500 dollars for a sound? You should only worry about venting when it is needed for performance. if you want sound get a dog whistle, drill two small holes, and blow on it in between each shift. it makes the same sound.. nice and loud. and will cost 1.25
V8's are like tampons, every pussy needs one!
Old 04-30-2004, 05:01 PM
Re: Re: Car wont idle when venting to atmosphere
LMAO!!!
like i said i can do it, but like Joe, i don't unless i'm going to be in Hollywood or pulling up to a club, and even then it is only like that for 2 days at the most. but it does make me smile realllllly big to hear that [i catch myself pinging it on purpose... lol]
Old 04-30-2004, 05:15 PM
95GSTRaCeR 95GSTRaCeR is offline
I can run mine vented all the time and it doesnt seem to have to much of an effect. but eventually you will notice a difference, might as well circulate, like BoostedSpyder said you can always run vented if you want to be noticed..it has to be one of the best sounds in the world
