Old 04-29-2004, 06:45 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
How do ya fix idle with BOV venting to atmosphere
The thread says it all i guess, my car stalls out it wont idle, and runs wiered at low rpm around 2000-3000 rpms, but runs great when not venting to atmosphere.
Thanx Eric
Old 04-29-2004, 08:01 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: How do ya fix idle with BOV venting to atmosphere
its easy... stop venting to the atomosphere or spend $500-$1200 on a maft
btw stop watching f&tf
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-30-2004, 10:01 AM
solow96talon solow96talon is offline
to fix your idle problem is quite simple. An aftermarket BOV would fix the problem as well as i've heard that crushing the stock bov would fix that too.
Old 04-30-2004, 02:10 PM
solow a aftermarket bov wont fix it neither will crushing the stock one the only way to fix it is a maft, vpc or recirculating check out the faq for the reasons i dont want to type them out
-1stGenRocks-
Old 04-30-2004, 03:12 PM
see that's what i was told before but after i added an HKS aftermarket bov and blocked off the recirculating pipe with a broom handle that whole problem i had with the rough idle went away and i haven't had a problem with it since
Old 04-30-2004, 06:54 PM
Talon69's Avatar
BTW!!!!!!!!!!! Has nothing to do with the fast and the furious...............
