Old 04-29-2004, 05:30 PM
CAUTION CAUTION is offline
Send a message via AIM to CAUTION
1990 Tach
alright my friend owns a 1990 civic hatchback adn it doesnt come with a tach which is ok cuz he can shift just fine with out one but hes lookin to add a small on just so he can do better shifts. does anyone know if the trany is pre wired for a tach or does he have to do it himself adn if he has to do it himself does anyone know how to.
Old 04-29-2004, 07:15 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: 1990 Tach
u hook it up through your ignition coil, its the blue wire comin off of it. Just tap into the blue wire and hook up the tach.
1991 Honda Civic DX Sedan
Old 04-29-2004, 11:32 PM
a91civic a91civic is offline
Also, You could take of the cluster cover and there will be a single blue wire in the harness going into the guage cluster I just tapped into that.
It is quite easier that having to run wires from under the hood.
Hope this helps!
Old 04-29-2004, 11:34 PM
Forgot to mention this.
you could go to a junk yard and grab a 90 or 91 SI (do not use a 88 or 89 they don't quite fit, but they will work) cluster w/tach and you can pull out the on in there now and replace it with the si one, and you will have a tach and no wiring, and maintain the stock look.
Old 04-30-2004, 07:55 AM
dagoEF's Avatar
dagoEF dagoEF is offline
Re: 1990 Tach
[quote=a91civic]Forgot to mention this.
88-89 will need to be rewired to work, I tried it already
Old 05-01-2004, 12:21 AM
travagliante's Avatar
travagliante travagliante is offline
Re: 1990 Tach
You can get one from a 90-91 Civic LX or EX and a CRX si.
If you get one from a 88-89 you need to reping the connectors but the wire colors are exactly the same.
