Old 04-29-2004, 04:02 PM
burban12 burban12 is offline
brakes squeak
Hello all,
I own a 1994 taurus and the brakes started squeaking so I changed the brake pads. Even though I change the pads it is still squeaking really bad. Is this common in Taurus' Any help would be greatly appreciated.
If your clean your not having fun
Old 05-01-2004, 05:12 PM
David Powell David Powell is offline
Re: brakes squeak
Hey there.
When you changed brake pads, did you surface the rotors, or turn them? I recomend when doing a brake job, turning the rotors, and putting a non-directional finish on them. Any good machine shop should do this for you when turning your rotors. I the machine shop that turns the rotors does not know about a Non-Directional finish, go somewhere else. This should take care of your noise. I just bought rotors from Advance Auto, and they came with the Non-Directional finish already. Clean the rotors well with brake cleaner. You should be good to go. Good luck
Old 05-04-2004, 12:25 PM
Re: brakes squeak
Thanks I will try that here in the next week and let you know the results.
