Old 01-14-2002, 08:00 AM
Bobj's Avatar
Bobj Bobj is offline
Evo V1 Wrc
Hi want to know the correct way to mask around window rubbers and line over roof as i dont want to stuff it up, there seems to be two lines i could run the tape along any help appreciated.
Old 01-16-2002, 10:29 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
For black trim, try using "black foil" from Bare Metal Foil Inc....It's used just as the chrome foil. If you are trying to do black trim strips, try Letraset fine line tape from a drafting supply house.
Russ
My AF Classic Model Car Gallery
Old 01-18-2002, 11:12 PM
primera man's Avatar
"P-Man"
Re: Evo V1 Wrc
Use Tamiya masking tape. Apply it over the whole roof line and press down firm. Run a very sharp modelling knife along the lines then remove the middle bit you are painting. Press down firmly again before painting.
Do the same for the windows. Place the tape around the windows then trace around the window frames and remove the piece to paint.
View All My Models Here.
Old 01-19-2002, 06:39 AM
Bobj's Avatar
Thanks that helps heaps.:flash:
