Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-29-2004, 08:32 AM
Kenneth Marshall Kenneth Marshall is offline
Unhappy '99 Grand Cherokee Tail Light
My driverside tail light goes out when I step on the brake. All bulbs are good. I have heard (and read on this forum) that this is a known problem. Does anyone know how to fix it?
Old 04-29-2004, 06:20 PM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
Re: '99 Grand Cherokee Tail Light
Nope, I dont, but Im sure someone will, there are lots of smart people when it comes to Jeeps in this forum.
Old 04-29-2004, 07:13 PM
rleman43 rleman43 is offline
First placei would look is to see if that tail light bulb is grounded properly in the socket itself.
I had a similar problem with a 89 Cherokee ..my front drivers side parking light would go out when i put the bright lights on...still confuses me today but it was a bad ground not making proper contact in the socket...i cleaned the socket and attached a piece of wire to ground the bulb better...anyway this fixed it.
oh yeah...also when this happen at the same time it also illuminated the left turn signal solid on the dash indicator.
Bad grounds in those sockets can cause wierd problems.
Old 05-02-2004, 06:58 PM
Bump.
Old 05-02-2004, 09:00 PM
jeepfixitman jeepfixitman is offline
Send a message via AIM to jeepfixitman
There is a known problem with the taillamp assemblys they have a set of contact boards built into them that sometimes bend or get hot and touch each other causing a new circuit to form resulting invarious defects. pull the lamps off and closely inspect the sockets especially the top ones the problem is usually there. Unfortunately the lamp comes as an assembly you cant get the boards seperate.
Old 05-03-2004, 10:58 AM
Thanks for the help. I now have an idea of what to look for.
Old 05-03-2004, 05:51 PM
Good work, jeepfixitman.
Old 05-04-2004, 12:02 PM
Yes..GJ nice to know.
Thanks
