Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-29-2004, 04:29 AM
buxfan buxfan is offline
Angry i havent a clue
I have a 92 t-bird with the 5.o H.O. engine, The fuel pump went out about 3 months ago so i replaced it and the fuel filter also. My problem is that 3 times in the past two months , i have went to start it and it wont, it turns over fine but acts like its not getting gas but this only lasts for about 2-3 hours then it fires right up like nothing is wrong and runs just fine. It never runs rough like the filter is getting dirty or anything, it doesnt give any warning at all....just wont start.......any ideas?????????
Old 04-29-2004, 05:38 PM
Mike75 Mike75 is offline
Re: i havent a clue
Throttle Position Sensor?
Sounds kinda similar to what happened with my 93 a few weeks ago. I got a new TPS for about 30 bucks from Autozone, and the problem went away.
Have them test if for you before you buy a new one, though. I watched the multimeter as they were doing it on mine, and saw the bad "spot" on it for myself.
Hope this helps.
Old 06-11-2004, 03:07 PM
mickhenny mickhenny is offline
Re: i havent a clue
I had the same problem when it was wet outside they replace the $12.00 starter coil
Old 06-13-2004, 02:48 AM
The ORIG. Dig. Oxy's Avatar
The ORIG. Dig. Oxy The ORIG. Dig. Oxy is offline
Re: i havent a clue
Codes, Codes, Codes.
Pull the codes, and see what the computer tells you is wrong.
Anything Worth Shooting, is Worth Shooting Twice
Ammo is Cheap. Life is Expensive.
Old 06-13-2004, 11:15 AM
91_T-Bird_HO_5.0's Avatar
91_T-Bird_HO_5.0 91_T-Bird_HO_5.0 is offline
Send a message via AIM to 91_T-Bird_HO_5.0 Send a message via MSN to 91_T-Bird_HO_5.0
Re: i havent a clue
there should be a fuel regulator sensor located in the truck on the drivers side, it should kinda look like a small refrigerator, well, it's shaped like one anyways, that is probably your problem, my t-bird was doing the same thing, i replaced that and it fixed the problem, i ended up replacing 5 fuel pumps in 2 years because of it, i wished i would have known about it sooner, maybe i could have saved my self alot of money
Old 06-13-2004, 11:43 AM
Re: i havent a clue
That's not a fuel regulator. It's a fuel pump cutoff switch. The idea behind in it to interrupt electricity to the fuel pump if the vehicle suffers a hard enough impact or rolls over.
But once that impact breaker is tripped, it requires physical contact, by the way of pushing that little red button back down. So, I can't see how his car starts after several hours of sitting there. But again, pull the codes.
