Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 04-29-2004, 12:59 AM
jajimo's Avatar
jajimo jajimo is offline
Launching with an Auto
Sounds stupid I know, but out of curiousity, what would happen if you put it in neutral at the light and revved up then when the light turns green throw it into D4 (or maybe lower)? It doesn't seem like it would be very good for the transmission, but are there any other serious consequences?
Old 04-29-2004, 02:20 AM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
Re: Launching with an Auto
not good for trannt or gears. but you would peel out just like a manual droping the hammer
Old 04-29-2004, 06:48 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Don't do it.
Old 04-29-2004, 08:52 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
your tranny will get out of the car slap you and then run to the battered womens shelter. its not a good idea. But if its a rental have a blast! also member they hate it when your doing 70 and throw it into R or so i've heard
Old 04-29-2004, 09:15 PM
YellowITR479 YellowITR479 is offline
Neutral Drop!!!
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 04-29-2004, 09:19 PM
Funny subject. My boy had an old 92 Integra LS w/ an auto and he would neutral drop it all the time ( I used to laugh my ass off every time he did it ) the car did it so smoothly, it was crazy, i think the car liked it. He never broke the tranny either ( totalled it instead ). My advise is dont do it though even though it is fun.
Old 04-30-2004, 01:19 AM
DkShadow's Avatar
DkShadow DkShadow is offline
Do it if you want to fuck up your transmission.
If you want to launch your auto, just flash the converter - off idle.
Old 05-01-2004, 03:41 PM
jajimo's Avatar
Okay so I accidentally did it last night (seriously, it was an accident). I was sitting at a red light with a friend and I put it into neutral and revved up to about 1700 and then I saw the light turned green so I let off and through it into D4 (there were people behind me, so I didn't want to piss them off). It didn't drop down to idle before I put it into D4 so it jumped a little.
Thanks for the info, I definitely won't be doing it (purposefully)!
Old 05-01-2004, 04:06 PM
MR2Driver's Avatar
MR2Driver MR2Driver is offline
If you want to launch an auto, hold down the brake and give it gas to keep your revs up, then when its time to go, drop the brakes and floor it
Old 05-01-2004, 04:33 PM
Janet Reno Janet Reno is offline
lol isn't that hard on...the brakes? Or the engine or drivetrain or whatever would be envolved?
Old 05-01-2004, 07:43 PM
DkShadow's Avatar
Whenever I launch I just launch off idle. I give it part throttle to get me out the hole and when I feel that the tires hooked up I floor it all the way. When I try to powerbrake before launching, I usually end up smoking the tires.
Old 05-03-2004, 08:14 PM
megaman277 megaman277 is offline
i would go with the powerbraking approach...cause u can somewhat control where you launch...kinda like launching a stick...and even if it messes up brakes, there a whole lot cheaper than transmissions
Old 05-04-2004, 08:21 PM
pizzaman pizzaman is offline
Holding down the brakes is the way to go. I used to do that in my Gand Am. Replacing brakes is cheaper than replacing the tranny.
Old 05-04-2004, 10:14 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
First off it's NOT hard on the brakes or even uses them since it's not slowing the car down. The car is already stopped, so it's just holding it in place, NOTHING of the brake pads/shes is used, so it's in no way bad to them. What it IS bad on is the tranny and also the motor. For the motor it's bad on the mounts since they are what cushin the engine's movement on the chassis. They end up soaking up a bit of the energy building up when doing this. On muscle cars, mounts would BREAK off the frame because those engines would have so much power and torque.
Now for the tranny side, it's bad on the torque converter, because all that energy builds uptinto heat which is the T/Q's number one enemy. If you torque launch as it's called, hold the car still for NO MORE than 10 seconds at a time, or risk frying your torque converter unit. For the stock tranny, a good launch like this can be had by holding the brakes just till the car feels like it's about to start moving. This shold be at about 2200 -2300 RPMs. Then as you take your foot off the brake, mash the accelerator to the floor, and enjoy the wheel spin, tire screeching and tire smoke that proceeds.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 05-05-2004, 06:33 PM
jajimo's Avatar
Maybe it's because my master cylinder is bad but if I hold down the brakes and press on the gas, the car immediately lurches forward =/
Or, maybe it's all that RAW Honda SOHC 2.2L power!
Check out more pics of my 1994 Accord Sedan on CarDomain.com.
JDM Black Housing Headlamps, RS*R ExMag Cat-Back, H&R Sport Springs, AEM Short Ram Intake, Redded Out Tail Lights, DIY Mugen Grill, Graphite Emblems.
