Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-28-2004, 08:08 PM
95sunfire 95sunfire is offline
Send a message via AIM to 95sunfire
fuel problem
i have a 95 sunfire with 13100 miles. lately it has been bogging down and hesitating alot on take off and sometimes sputtering right when i start it. i have found though if i take off from a stop very slowly picking up speed and not hitting the gas hard that it wont sputter and hesitate. i changed the fuel filter and added some cleaner to the tank and that didnt work so i took it to a mechaninc and he said he couldnt find anything wrong with it. i changed the fuel pump a few years ago when it went out but i dont remember it acting like this last time it went out. i just wondered if my pump is bad again or if my injectors are bad. once i get up to a constant speed it is usually fine.
Old 04-29-2004, 02:52 AM
slappy180 slappy180 is offline
Re: fuel problem
u need to get a full servise maintance tun-up.the cleaner u put in the tank cleans your injectors put it moves the gunk into your engine.put u need a tun-up bad
Old 05-05-2004, 08:53 PM
noize1er noize1er is offline
Thumbs up none
bad fuel injectors. or the throttle body. yah and, tune up
Old 05-12-2004, 06:15 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: fuel problem
Three things I want you to check.
1. Take out your IAC (Idle Air Control solenoid) which is located on the throttle body. Clean it with a throttle body cleaner and a brush. Clean the spot where the IAC goes in to the throttle body.
If that does not work you may have to replace the IAC $29.
2. The TPS (Throttle Position Sensor) also causes problem which is located below the IAC. The TPS at IDLE provides voltage value to the computer and that's what how computer determine the position of the throttle plate. If there is a dead spot on the TPS providing incorrect voltage then it will throw the computer a little bit. The TPS can't be cleaned and you just have to replace it $19.
3. The MAF (Mass Air Flow sensor usually located right after the air filter box) or ACT (Air Charge Temperature sensor usually located on the side of the air filter box). Try cleaning them with some throttle body cleaner and let it dry.
Check the connectors as well of all sensors.
Old 05-12-2004, 06:28 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: fuel problem
Slade got the right idea.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
