Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 04-28-2004, 08:00 PM
unholy unholy is offline
Question I have some problems, think you can help?
Ok, I'm new to the forums and i have a question if anyone can help me. I'm having an idle problem with my 89' 626. When I bought the car it ran fine, the fan and heater worked. Then an idle problem started and everything went to hell. See, the problem is that my engine's idle, stared and has been for 5 months, bounces between 1200 and 2000 when it gets hot, and stays between 1500 and 1900 when it is cold. The thing that puzzles me is that when the engine hits a certain temp it idles fine. Then when that temp is passed it begins bouncing again. Yes, I have replaced my thermostat, but my fan and heater still do not kick in at all can anyone help me?
p.s. The fan and heater do work when using jumper wire to connect themto a power source.
Old 04-28-2004, 08:28 PM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
check engine light on? , sounds like the temp sensor or switch is bad
Old 04-29-2004, 08:01 AM
Re: I have some problems, think you can help?
No engine light. Which sensor do you think it would be I got four, of them i'm pretty sure.
Old 04-29-2004, 02:35 PM
you need to get ahold of a scan tool and see if it finds anything
Old 04-30-2004, 01:26 PM
The scan tool that I can get my hands on does not have the adapter for my car
