Old 04-28-2004, 07:48 PM
SJ-91LX SJ-91LX is offline
ZC swap please help..
4 door 1991 LX 1.5
JDM ZC Swap DOHC
PG7 ECU no resistor box
Runs fine up to 3500rpms then it starts to rev limit.
Codes are crank angle sensor and electrical load.
Any ideas as to what's wrong?
Thanks
Old 04-28-2004, 09:11 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: ZC swap please help..
Make sure your belt riming is correct. That is usually the cause of the crank angle sensor code. If the timing is right than perhaps the sensor is bad.
Old 04-29-2004, 12:24 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Crank angle sensor is in your distributor - might have a bad one - or your timing is off. Start there. Mine did the same thing when my distributor wasn't working right.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 04-29-2004, 02:05 PM
Got a new distributor and that got rid of the crank angle code but the electrical load is still coming up and the engine is still doing the same thing after 3500rpms.
Old 04-30-2004, 12:55 PM
Do you guys know if there is a difference in the wiring for the LX and DX? Every site shows the DX to ZC wiring, but nothing for the LX.
Old 04-30-2004, 01:45 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
why no resistor box?? what injectors are you running?
SOLD!
Old 04-30-2004, 05:17 PM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
that electrical load is probly from not having a resistor box ... to much voltage running through the system without anything to check it. yea and what injectors and stuff like that guy said.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 04-30-2004, 10:48 PM
It does the same thing with or without the resistor box
Old 05-01-2004, 04:11 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
maybe your ecu is screwed, are you sure you didnt accidently put your lx one back in by mistake
KoRnSaQ
Old 05-01-2004, 09:21 AM
Yeah Im sure. We've tried two PG7 ecus and still no luck. :|
Old 05-01-2004, 10:01 AM
4G4D Store's Avatar
Wow - I'm drawing a blank. The only thing I can think of is double check your wiring. The stock wiring should be fine, so I'd just say check your wiring again and make sure the wires aren't grounding out somewhere on the firewall or are backwards. I'm not sure if the electrical load is refering to a specific thing, or if it's just a general "electrical load" error. Good Luck though.
Old 05-01-2004, 10:03 AM
4G4D Store's Avatar
Just another thought really quick - have you reset your ECU???
Old 05-01-2004, 10:58 AM
travagliante's Avatar
travagliante travagliante is offline
Re: Re: ZC swap please help..
Is it a good resistor box? They can go bad. And you MUST have a resistor box or solder resistors between every injector or the engine will not work properly. That has to be the problem.
Old 05-01-2004, 11:05 PM
Just posting these links for someone to see.
Thanks for the suggestions so far.
http://www.fourthgenhatch.com/zc.html
http://www.fourthgenhatch.com/mpfi.html
Old 05-02-2004, 12:10 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
just an fyi....
you need a pg7 ecu from either an 88 or 89 integra. the earlier 86-87 pg7 are different.
when i did my zc, i had some issues with the distributor, but after i replaced it, everything was fine
good luck
There's nary an animal alive that can outrun a greased Scotsman!
