Old 04-28-2004, 05:59 PM
tacoma man tacoma man is offline
rear end thumps when i pull out.
if i try to burn my tires when i pull out my rear end thumps.
it doesnt if i pull out smoothly. whats wrong?
Old 04-28-2004, 06:00 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: rear end thumps when i pull out.
does it hop?? or does it make a loud thump with no vibration
Old 04-28-2004, 06:58 PM
loud thump w/no vibration
Old 04-28-2004, 07:07 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
is it a knock or a thump? metal to metal? Does it do it if you hit a big bump?
Old 04-28-2004, 07:15 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
this post is here twice????? eh, posted on the other one, to lazy to post again
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-28-2004, 07:17 PM
its like its got a chip gone off one of the spider
gears and it catches when i pull out
Old 04-28-2004, 07:28 PM
DaMoNe6969's Avatar
Well if it was only when you step on it, Ide lean away from suspension and say that the problem lies in your drivetrain...Are you sure the sound isnt coming from your tranny? Check the simplest things first though, check the universals and driveshaft for play.. if nothing there, you'l havta pull your diff cover off and check the magnet, then visually inspect the spyders, axles, etc..
Old 04-28-2004, 08:46 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
does it feel like the rear end is going to roll out of it?
i had almost the exact same problem right before the spider gears broke and took out some teeth on the ring and pinion.
Old 04-28-2004, 08:49 PM
89IROC&RS's Avatar
could be many things, rear end (differential) could be loose, although thats more of a bang, could have a damaged or missing bushing somewhere on the suspention, could have a loose bolt or nut on the torque arm, lots of stuff. hard to say without actually being there. damn internet
Old 04-28-2004, 08:55 PM
4onFloor's Avatar
my problem was that the dumbass that changed the gears before me didn't set either the pinion depth right, or didn't set the ring to pinion clearence right. when ever i'd stomp it, i think it was either binding or changing the angle of the pinion. didn't make any gring noises or bangs, just made a dull thump and felt like the rear end was rolling out of it
