Old 04-28-2004, 05:08 PM
2xKlutch 2xKlutch is offline
Need help w/ wheels!!
I have '90 eclipse GS. It is currently sitting @ stock height. I was wondering if anyone has the same car, and if so what size rims & tires you use so that they will not rub or interfere w/ the steering. I don't want to use spacers. It is a 5-lug. Currently on 16" rims. Appreciate and input. Thanks.
Old 04-28-2004, 05:35 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Need help w/ wheels!!
You can use 17'' wheels or 16'', then get tires with a sidewall height to match stock diameter.
Old 04-28-2004, 05:57 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
as long as you keep a 35mm offset or greater you should be fine. you can easily fit 17's on the car should you desire to do so. lowering the car will help with appearence and handling but increases your chances of rubbing the suspension. either way I doubt you'll have too much trouble.stick with a 17x7 and you'll be good to go. Good luck
V8's are like tampons, every pussy needs one!
