Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-28-2004, 04:55 PM
dougthegreat dougthegreat is offline
Getting the plastic instrument window off...
Hey everyone. I have a 1999 Honda Accord EX-V6.
I'm trying to get the plastic window that covers the tach, speedometer, gas and temp gauges off because there is some smudging behind it that is ticking me off. Is there an easy way to do this that doesn't involve removing half the dashboard?
Thanks In Advance!
Full leather interior
Heather Mist exterior, Ivory interior
It may not be much, but it's mine!
Old 04-28-2004, 11:14 PM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
You have to remove the whole cluster.
The clear glass snaps onto the surrounding parts. Its impossible to remove it without the cluster in your hands.
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
Old 04-29-2004, 06:24 PM
Ehhhh... thanks.
So to remove said cluster, do you just take off the two screws above the window?
Old 04-30-2004, 10:47 AM
I am not sure how to on an Accord, you have to remove a bezel around the cluster and then clustershould have 4 screws holding in.
Brandon
Old 04-30-2004, 11:04 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Getting the plastic instrument window off...
It's not that simple on the later models. I don't have a manual for that new an Accord, so I won't try.
Old 04-30-2004, 12:09 PM
mjshort18 mjshort18 is offline
Re: Re: Getting the plastic instrument window off...
well if you see the 2 screws above the window you take them out and then the plastic peice that goes around the see through part will pop out but you have to pull a little bit to get the clips to let loose. then you should see some screws that are around the see through part and the rest should be self explainatory. this is how i did it on my 98 civic and i am pretty sure it is close to if not the same as the accord. while you are doing it just make sure you get all the screws and inspect for the places it pops out. you should be fine, just try.
Old 04-30-2004, 01:56 PM
Hey-
I tried unscrewing those two screws from the top (which was freakin' hard with the steering wheel/column in the way), and it didn't quite come off. The top part of the black plastic piece would come, but it seemed like it was snagging on something on the bottom. I didn't see any other screws besides those two. You say there are clips on the bottom? Any ideas on how to get it off without breaking those clips? I really don't want to buy a new one
Old 04-30-2004, 02:40 PM
i had to just wedge my fingers in there or just get as low as possible and pull and then they popped off. just be careful because they can break, one of mine broke but it still goes on fine and you can't tell. hope this helps.
