Old 04-28-2004, 02:39 PM
KWandKD KWandKD is offline
Lightbulb Beginner Engine Question
I know it may seem obviouse to some of you, but I have a few quick questions again.
What is the difference between the 93-94 7-bolt engine and the 97 7-bolt engine?
Will a 93 7-bolt engine fit directly into my 97 gsx?
If not - what steps need to be taken (any major parts, labor work)
Last - How much power (compared to the original motor) will I lose?
The 93 engine im putting in there has no modifications what so ever -
Thanks again if you answer any of these questions, Im just trying to get some answers from people who DO know what there doing.
(The Engine won't cost me a thing to get, so Thats why im wondering If I should replace the one I have in it now. The one I have in it now has 105,000 and I want to start modifying heavy) please let me know wut u think.
Old 04-28-2004, 02:57 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Beginner Engine Question
if you are going to replace it, get a 6-bolt 4g63 if you can. other wise as long as it is a 4g63 it will be a direct fit.
Old 04-28-2004, 03:37 PM
Soo... I can switch the 2 motors, with no modification fits, and still use the mods I have on my car now for the new engine?
(Put the 93' talon motor in, and still use the upper intercooler pipe, stock t25 turbo, and downpipe w/ exhaust ect.. from the motor I have now) Right?
Sorry if it sounds stupid, but I dont wanna risk it by doing something that'll F' up my car.
Old 04-28-2004, 03:56 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
yes ,as long as your just replaying the block and head
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-29-2004, 06:53 PM
boostedinaz boostedinaz is offline
Send a message via AIM to boostedinaz
There is more to it than that. The main thing is that a 2G uses a Crank Angle sensor to tell the ECU when to fire plugs and injectors. The 1G motor will use a Cam Angle sensor to do the same. If you go to a DSM specific site (www.dsmtuners.com www.dsmtalk.com www.teamnabr.com ) and search for this swap you will find all the little things that need to be done. I also wanna say that the motor mounts are different but I believe that this is only for the oe on the tranny. If you keep the stock tranny you should be fine.
Michael
Old 04-29-2004, 09:58 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
the only motor mount that is different is the one on the motor... very right side if looking into the engine bay!
EclipseRST's Avatar
Banned
oh yea... here is a site that explains it well!
http://www.magnusmotorsports.com/1g2g.asp
