Old 04-28-2004, 02:17 PM
Mram76 Mram76 is offline
Unhappy spark plug had fuel on it
hey.. u all.. i have 99 rs... could not afford the GSX or GS-T. Don't under estimate the RS. ok hear is my situation, my car was idle low about 500 when i stop at light or stop.... but the car drive fine in driving.... i thought it was my spark plugs, so i decided to change it and i found one of them had fuel on it.... what is happen is my fuel injector leaking or just went bad... help....... by the way i am a newbie to this forum i am trying to learn more about my car... the eclipses are great machine....
Thanks guy......
Old 04-28-2004, 02:46 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: spark plug had fuel on it
what is it your asking help with.
Old 04-28-2004, 03:10 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
That he has fuel on his spark plugs
For Sale 98 Eclipse GS, 5 spd
Old 04-28-2004, 03:29 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
I think that means your running too rich.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 04-28-2004, 04:56 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Re: spark plug had fuel on it
^^what he said
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-30-2004, 03:50 PM
i change my plugs but out of the 4 of them one had a lot of fuel on it... could that be cause me to idle low at a light........ please help... my car idle low at the stop light....... i change it a few months ago an all four had no fuel..... but knoww??????
Old 04-30-2004, 03:55 PM
ashah000's Avatar
How low is your idle
Old 04-30-2004, 04:22 PM
95GSTRaCeR 95GSTRaCeR is offline
wow....took awhile to....decipher this post..and find the problem...dont underestimate the rs? dont underestimate the power of the period (in your case), lol im just kidding with you. So as I understand it, your idle sits at 500 rpm's at a stop?
Old 04-30-2004, 05:14 PM
ashah000's Avatar
Oops missed the 500.
CEL?
Old 04-30-2004, 05:16 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
replace the plugs with [ashah plug in the correct part # please] BPR5ES [?] and be sure they are gaped to the correct specs [again ashah ].
make sure your wires are good and pluged in and there is no excess FOD in the plug wells
Old 05-04-2004, 11:44 AM
sorry about that .. but ur right - - -ashah000 i am idling at 500 at a stop light. brought a new ngk plugs... the new ones i just put in, when i discover there was fuel on one of the old ones.... i am still driving my car with this low idle.
BoostedSpyder: what is excess FOD?????
Old 05-04-2004, 06:34 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
hmm, just making sure i get this right, but the spark plug is wet with fuel when u take it out?
just dont how that is possible, since the temp in the combustion chamber will dry it up.
-Agim
Old 05-04-2004, 07:39 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
so your spark plug was bad and didn't ignite the fuel (that made the plug wet) what's the problem here?
Old 05-04-2004, 07:57 PM
ashah000's Avatar
Re: Re: Re: spark plug had fuel on it
Oops I missed this...
Yep BPR5ES or BPR6ES, I would go with the 5.
Gap them to .045 to .050
Ok then did the new plugs help at all?
Are you sure it is fuel
So there is no check engine light?
Old 05-04-2004, 08:42 PM
Re: Re: Re: Re: spark plug had fuel on it
FOD = Foreign Object Debris
like crap down in the wells. the electricity will follow the least amount of resistance and it may be leaving your plug wire and going thru a tiny hole it has burned thru it by where the wire taps the plug, arcing to some conductive water or something. there is a page by magnacore all about it [ya, so what if i'm lazy!].
