Old 04-28-2004, 11:23 AM
JimCRX's Avatar
JimCRX JimCRX is offline
TPS Sensor?
This problem has gotten worse now. I just had my valves adjusted because they were tapping bad. I took off my IAVC cleaned it and all and I still have the idle problem. I even put a resistor on the IAVC so the idle would go by the screw only and still nothin. Whenever I come to a stop it will constating rise and fall, rise and fall etc...Now like say I shift at 3,500rpms it'll hang and idle at like 3,000 for a minute then drop and etc. I was told that this probably is a bad TPS Sensor. What exactly does it control? I know it's on the throttle body and it's mounted in it pretty good so I would probably have to get a whole TB?
Old 04-28-2004, 11:47 AM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
Re: TPS Sensor?
TPS controls most anything that has to do with electrics and intake... does it bog or run poorly when you're at WOT? or does it seem to do funny stuff through out the time you push the throttle? it sounds like a bad IAVC it's annoying but it doesn't mess anything up. mine does it and i'm still pulling some good times.
Old 04-28-2004, 01:09 PM
90stdhatch 90stdhatch is offline
Re: TPS Sensor?
possibly a intake manifold leak, throttle body or a vaccum leak of some sort. make sure every thing is torqued to oem spec and vaccum lines are routed correctly.
Old 04-28-2004, 01:36 PM
JimCRX's Avatar
Re: TPS Sensor?
Yeah, it runs poorly, but doesn't bog. I doubt it's the IAVC. I disconnected the IAVC and hook a resistor up to the plug so it wont go by the IAVC, only the screw and that didnt make a difference. It seems to be hanging around 2-3,000rpms. Like if shift at 3,200rpms, it will sit and idle around 3k rpms for like a minute then drop and rise hang a little bit, drop and rise etc...Vaccum lines are fine and the bolts are fine.
Old 04-28-2004, 02:30 PM
wickedplastikman wickedplastikman is offline
Re: TPS Sensor?
i have the same problem on my b16 crx. my idle was rising and falling the same as yours. i unplugged the sensor on the iavc for now and it fixed the problem. i tried to clean the iavc and it didn't do anything so i am going to the yard and pulling off another one.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
