Old 04-28-2004, 09:33 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Ghetto fab that works...
OK all, I wanna know about ghetto tricks you guys have used that actually work... Here's my contribution: Get a couple or 3 washers, some longer 10mm bolts, and put a couple of washers between your hood and hood brackets. It lifts your hood up just a little and increases air flow. I saw some "kits" for it on ebay and decided to give it a shot with washers I had at home. I did it a couple weeks ago, and since then my temp needle deflects just a little bit down, maybe by 1/8th or 1/4. It's cheap and easy, works ok. Lemme know if you guys have done anything like that at all that worked.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 04-28-2004, 09:53 AM
travagliante's Avatar
travagliante travagliante is offline
Re: Ghetto fab that works...
um i dont know what to say...
Old 04-28-2004, 10:07 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: Re: Ghetto fab that works...
so wtf did u post for then :roll: Whore
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 04-28-2004, 11:09 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Heres a couple more...
-High beam headlight in low beam's place
-90-91 civic clear bumper lenses (just pop out orange plastic piece)
-Headlight buzzer from home depot.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 04-28-2004, 11:23 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
you can also use a longer bolt and some washers to fix rear camber
there are a lot of "tricks" out there. let's hear some good ones i can add to the how-to section
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 04-28-2004, 11:57 AM
4GZChatch's Avatar
Ami, what length bolts and how many washers? Where can you get the bolts at? I need to do that one soon!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 04-28-2004, 11:23 PM
amy@af's Avatar
all we ended up doing was adding a washer or 2 to the stock bolt. i originally heard you needed a longer bolt. i would say to pull the stock one out and take it down to an automotive store and ask for a longer bolt.
it's always been a very general how-to. there never was an exact science of specific length bolt or number of washers. it's more a trial and error process depending on how low you are.
Old 04-29-2004, 12:03 AM
4GZChatch's Avatar
Yeah, I've heard about that one for a long time, just forgot about it, I guess. I am down about 1.7", so I guess I'll just try throwing on a couple of washers and seeing if that straightens it out some... How much are you lowered on your car?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 04-29-2004, 01:17 AM
lilol89crx lilol89crx is offline
removing key switch for buzzer-remove plastic covering ign assembly. under ign cyl there is a little black box with 2 blue wires, cut one or both wires and ur buzzer wont work with door open and key in ign.
brighter dash lights-remove guage cluster, remove front cover from cluster, remove individual guages. use rubbing alchohol on Q-tip and rub off all the black stuff off the back of the guage.
short shifter-buy a universal shifter handle(the kind with the 3 set screws), hacksaw about 3-4 inches off of shifter itself. install new shifter handle.(shortens throw by roughly 10-15%)
Old 04-29-2004, 11:07 AM
amy@af's Avatar
i have coilovers so i dunno exactly. but i can say it's much more than 1.7"...1 washer should do you fine. if anything i would try to find a washer on the thicker side. that way you get the difference of a washer & 1/2 with just 1 washer
Old 04-29-2004, 11:21 PM
shaddr3 shaddr3 is offline
Send a message via AIM to shaddr3
Why use washers, use the rubber wide washerlike things..? Ya kno the stoppers.
89 CRX Si
B16 | BW Body kit | 17" 8 Spoke | Airbagged
Old 04-30-2004, 12:02 AM
LOUDCRXSi's Avatar
LOUDCRXSi LOUDCRXSi is offline
Send a message via AIM to LOUDCRXSi Send a message via Yahoo to LOUDCRXSi
when u use the washers ur ur rear chamber you need to get 3/8 washers and ever washer u add gives you a 1/2 degree. 1/2 inch = 1/2 degree. 2 washers are good for the stock bolt. 3 is pushing it but will still do. nething more than that you need to get a longer bolt. with ur car bein lowered 1.7 in the rear you will be fine with 3 washers. i have mine lowed 1.5 in the back just for suspension reasons and 3 is workin good for me. and LadyNRedSi, if you wana know how low u are just jack ur car up and messure the amount from the top tread on ur coilover to the bottom of the metal washer (or whatever the piece is that ur adjust).
Old 04-30-2004, 11:21 AM
amy@af's Avatar
good to hear somebody has figured out a science to the bolt & washer thing! mind if i add it to the how-to section? even if your numbers are slightly off (not saying that they are) it's still better than the general answer of a bolt and some washers.
Old 04-30-2004, 05:39 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
old air cooled VDub trick
Heres mine:
use 6ga battery cable for lawn mowers from walmart ($2.50 ea.) for grounds in your engine compartment. I have 4, ($10 total) one to the trans (for starter), one to the alternator, one to the head (spark plugs), and one to my trunk mounted battery. Much higher capacity than stock 8ga, and cheaper than ebay ground kits.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 04-30-2004, 10:42 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
damn man thats pretty sweet, i thought that maybe i had been having some grounding problems but it was just that my spark plug wire boots were loose so its all fixed now. But thats a pretty nifty trick.
1991 Honda Civic DX Sedan
