Old 04-27-2004, 11:09 PM
gebster76 gebster76 is offline
is there a trick to install 6x9's 01' GA??
for some reason I cant get the rear covers off. Is there a latch I am missing or what? Help.
Gabe
Old 04-28-2004, 02:39 AM
shark2000's Avatar
shark2000 shark2000 is offline
Send a message via ICQ to shark2000 Send a message via MSN to shark2000
Re: is there a trick to install 6x9's 01' GA??
If you read through all the posts, you would find the fallowing quote from Markgase2000
Wow this is one of the most common questions in here as of late.
Pull both rear seat backings down to expose the trunk space. There’s a plastic guard on the upper threshold held on by simple plastic pull pins , use a screw driver or a trim panel tool to pop them out and remove the guard. Then the speaker shelf cover comes out by pushing up a bit and pulling out."on the 6x9's in back get as far as removing that plastic piece behind the seats, and on the speakers in the front doors how does that cover pop off? im sure it needs a bit of force to pop off i just don’t want to break it. " <----- it comes out gently and the pins are cheap but still reusable so when you pullem out pull straight out not crooked.
The 6x9's come out easily , no screws just two push tabs and tilt it out , unclip the wire harnesses don’t touch the light bulb , unless you like 3rd degree burns lol. hope that helps out.
Good luck and happy upgrading. That's one upgrade I plan on in the future. My next, for now, is the exhaust.
My Grand Am Picture Site
_____________________________________________
2002 Grand Am GT
77 Dodge Power Wagon
2006 Charger SXT 3.5L V-6
2011 Charger RT 5.7L Hemi
2008 CLK350 Convertible
