Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-27-2004, 10:54 PM
mattilude mattilude is offline
Send a message via AIM to mattilude Send a message via MSN to mattilude
Chips??
I have a 93' Prelude SI H23.. i'm wondering if these things can be chipped.. and what chip do you guys recommend if possible.. Thanks -matt-
Old 04-28-2004, 12:59 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: Chips??
I haven't heard of any programs for the p14. I imagine it can be chipped, but then... why?
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 04-28-2004, 07:59 PM
Re: Chips??
why? horsepower.. that's why
Old 04-28-2004, 10:00 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
To tell you the truth, i doubt theres much horsepower to be gained with a random "chip", most of them just dump more fuel. The only reason I see anyone needing their ecu to be "chipped" is to raise redline.
If you want a *REAL* horsepower gain, invest in an air/fuel controller, or a piggyback ecu.
Just my opinion..
Old 04-29-2004, 03:35 AM
error54 error54 is offline
Send a message via AIM to error54
Re: Chips??
Check http://www.hondata.com
They make chips for hondas. The s200 chip does many useful things more than just getting rid of your speed govenor(which is cool also). You don't really need to chip unless you have soem SERIOUS mods in your car.
Import vs Domestic
-Brain vs Brawn-
To Each his own....
Old 04-29-2004, 05:22 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Chips??
In most cases you will loose hp with a random chip. The only way to correctly chip a car is to do it on a dyno with an wideband. Any tuner can do this, they will use a program such as hondata's and set values for x amount of pressure from the map sensor, then they will do a pull and see where in the power band settings need to be changed.
