Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-27-2004, 06:44 PM
deb789 deb789 is offline
Heater Core For 98 Pontiac Grandam
How much does this part cost? How much labor? We bypass ours. I just want to know the steps on fixing this heater core. Please!!!
Old 04-28-2004, 01:51 PM
Re: Heater Core For 98 Pontiac Grandam
Please help!! On 98 grand am heater core removal. Is this the same removal as the topic on the 95 Pontiac grandam se heater core.
Old 04-28-2004, 08:16 PM
GRANDAMLD9 GRANDAMLD9 is offline
Banned
Send a message via AIM to GRANDAMLD9
a heater core is going to run you about 50 bucks if you buy it yourself maybe less. labor is what is going to kill you. but if you do it yourself your only spending 50 or so bucks. i had mine done by my stepfathers friend. he did it on the side at his work and charged us 200 for the whole job. but to get to it you have to take apart you whole dash.
Old 08-19-2005, 01:01 AM
zismat06 zismat06 is offline
Send a message via AIM to zismat06
Well actually its not going to kill u i had the same problem this one shop told me 768$ and i started to panic the guy was full of crap hes like yeah you have to remove the whole dash its a 8 hour job. Bull all u have to do is slide the center counsol. I had it done for $165 laybor. 2 hours
Old 08-19-2005, 05:19 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Both of the responses to your question are more than correct. The heater core is cheap while the labor is very expensive. Get a manual for your car and replace it yourself. On this particular model you should be able to do it in a couple of hours. As stated the entire dash does not need to be pulled just the center. You really should do it soon since you are losing both coolant capacity and additional cooling ability, not to mention fall is just around the corner.
Old 08-19-2005, 09:47 AM
Drova Drova is offline
First time i've ever seen a heater core was in my 96 grand am, didn't have the slightest clue where it was and once i figured out how to get it out it took me about 2-3 hours and cost $20 something for the after market heater core + Coolent. Hardest part was putting the hoses back on in by the firewall. Remember to take out the center console it will make life alot easier. Its Under the dash in the middle, take out console, then theres some heater piping which is simple to remove then the heater core is in a box above that.
Old 08-19-2005, 10:22 AM
Hollowcreek Hollowcreek is offline
I paid $35 for a replacemnt metal (not the oem plastic one) and $150 labor at a local radiator shop. Go with a specialist and stay away from dealers and general service places for stuff like this. They don't want to do the work generally and try to discourage by quoting rediculous labor costs like the $700+ above.
Closed Thread
