Old 04-27-2004, 06:19 PM
icculus723 icculus723 is offline
94 accord remove door panels
just wondering if anyone knew how to remove the door panels off a 94 accord. thanks,
Old 04-27-2004, 06:43 PM
92lx 92lx is offline
Re: 94 accord remove door panels
very simple, just remove the screws, basically, they are behind all the little "tabs" that hide them, very easy to spot. Then, use a careful, forceful prying action to release the clips that are located all around the perimiter of the door.
Hope that helps.
- Nathan
Old 04-28-2004, 09:53 AM
AccordCodger AccordCodger is offline
I just gotta add an anecdote about a problem I ran into. The exterior door handle didn't open the door, so I started to take the door apart to check it. Removed the inside handle, then accidentally let the door shut. It took me a while to re-bolt my brain and decide I'd have to put the inside handle BACK in order to open the door, so I could THEN take off the door panel (you can't get it off when the door's closed)!
