Old 04-27-2004, 04:17 PM
willy2 willy2 is offline
cooling fan
my 92 accord when I shut it down the cooling fan comes on even when the engine is cool????can anyone help me!!!
Old 04-27-2004, 06:07 PM
Tom_91_LX Tom_91_LX is offline
Re: cooling fan
Does it run continuously, or shut off after 5-10 minutes?
Old 04-27-2004, 06:45 PM
92lx 92lx is offline
Re: cooling fan
if it runs continuously, that's bad, otherwise, it's normal.
- Nathan
Old 04-28-2004, 09:55 AM
AccordCodger AccordCodger is offline
Re: cooling fan
Indeed, depending what will2 means by "cool," the fan can cycle on and off a number of times for several minutes until the temp is low enough for it not to run any more.
Old 04-28-2004, 12:57 PM
Re: cooling fan
Thanks for responding to my problem...I just parked the car about 10 min. ago and when I went back out the fan was off,but I turned the key on and off and the fan cut back in again,I changed the relay fuse in her but that never worked.I was told it may be the temp. sensor?????
Old 04-28-2004, 01:03 PM
Re: Re: cooling fan
Again after about 10 mins the fan shut down, would this be a timer senor of some kind???????
Old 04-28-2004, 01:04 PM
Re: cooling fan
I don't think 10 minutes is all that long, IF the motor was pretty hot when you parked (and maybe I should ask what the temp gauge indicates?)
The behavior of that fan is, IMHO, rather idiosyncratic, but could the cut-in of the fan with your switching the ign on/off be coincidence?
Old 04-28-2004, 01:35 PM
Re: cooling fan
the temp gauge was about half way up on the gauge.But I know that this was not happening before.... a couple of days ago.Its now been about 1/2 hr since I had the car started I'll try turning the key on/off again and see if it comes back on and check the gauge to see where the hand is....
Old 04-28-2004, 01:39 PM
Re: Re: cooling fan
I turned the key on/off again and the fan came on,the temp. gauge is reading cold.....
