Old 04-27-2004, 10:31 AM
93blazer 93blazer is offline
Question How to remove gas tank
Does anyone know how to remove the gas tank from a 93 blazer. My fuel pump crapped out and I want to replace it. I removed the skid plate from under the gas tank and loosened the 2 straps. The gas tank won't move and I can't see any other bolts holding it in place. The Haynes manual is no help with this. Has anyone done this?
Thanks,
Old 04-27-2004, 10:44 AM
Rowlin Rowlin is offline
Re: How to remove gas tank
did u get the filler neck and the 3 line comming out of the top?
the sending unit have a few wire but u can see the once u get the tanl down a bit the groun is located on the rear cross member on the top with a 13mil self tapper. there is just the 2 lower straps with 4 bolts attaching them
Old 04-27-2004, 10:46 AM
Gas tank
Removed the Filler neckbut couldn't get to the 2 fuel lines.
Old 04-27-2004, 10:50 AM
if they are rubber u can probally just cut them and replace it i would replace the sending unit if there is any signs of rust. just yank can there are straps on the top but they dont affect u. i did my 90 2 weeks ago on the road and juts straps and lines i might be rusted pretty good
the straps have to be completely removed
Old 04-27-2004, 10:58 AM
Thanks for the quick reply. I remove the straps completely and give it a tug. Thanks.
Old 04-27-2004, 10:59 AM
mikeyk22 mikeyk22 is offline
dont cut the lines, they will not hold the tank in. also, new straps are really cheap from gm
Old 04-27-2004, 11:12 AM
new lines are cheeper and something u always should replace and the straps if they are not rotted don't replace them
Old 04-27-2004, 11:16 AM
big ole loser big ole loser is offline
Banned
before you remove the tank bolts make sure you heat up the nuts with a torch.
Old 04-27-2004, 11:22 AM
Not sure about heating tank bolts up with a torch. Kaboom!
Old 04-27-2004, 11:27 AM
but then u wouldn't have to worry about the fuel pump
