Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-27-2004, 05:51 AM
KevinCG316 KevinCG316 is offline
2001 Malibu Keyless Entry Program??
I just bought the keyless remote off of ebay and wanna program it. I searched all over and found nothing on how to do it. Is it possbile? if so please let me know how without taking it to the dealer. Again it is for a 2001 Chevy Malibu
TYVM
Kevin
Old 06-22-2004, 03:29 AM
ambriz ambriz is offline
Re: 2001 Malibu Keyless Entry Program??
TYVM
Kevin
try this.....pasted:
spotco2
Close all the vehicle doors.
Remove the ignition key from the ignition lock cylinder.
Important
In order to successfully enter the keyless entry programming/diagnostic mode, you must complete steps 4-6 within 25 seconds of pressing the door unlock switch.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. Keep the ignition in the LOCK position for the rest of the procedure.
Release the door lock switch. The chime will sound 3 chimes, which signals that the transmitter programming/diagnostic mode is active.
Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times which signals that the transmitter has been programmed successfully.
Repeat step 7 for each of the four transmitters.
Perform either of the following final procedures:
Turn the ignition switch to the RUN position.
Remove the ignition key from the ignition switch
