Old 04-26-2004, 09:36 PM
mitsuGTvr4 mitsuGTvr4 is offline
Question advice
Hi,
This is my first time writing on this forum. So, I just bought a 1994 Mistubishi 3000GT VR-4, very close to mint condition. It has 109xxx miles on it, and I am wondering if any of you guys can give me some advice on stuff to do, to keep it running well. Any things you guys do to keep yours in good condition??
any advice or suggestions would be great..thanks
Old 04-26-2004, 09:48 PM
azn3000GTRacer azn3000GTRacer is offline
Re: advice
Originally Posted by mitsuGTvr4
Hi,
change your oil every 3000 miles lol
well u proably already know that. Since u past the 100k point u should check ur belts and make sure they are in good condition if not changing them wouldnt hurt. The engine thats in our car are good engines if u keep up good maintence it should go well pass 150k. Pretty much check ur booklet and look at the 60k service manual and see if any of those parts need to be replaced. Oh yea if u havent yet invest around 150-200 dollars on a turbo timer they can really save your turbos inless u like to wait a good 2-3 mins everytime u drive your from place to place and wait for the oil to cool.
Old 04-26-2004, 09:55 PM
Question cd changer/turbo timer
O yea, one more thing. In the CD changer, which is the stock infinity one i think, i put 2 cd's in there, and hit the cd button on the radio, and it says disk one, but wont play...? anyhelp
also..being only 17, im looking for some good stuff that will last, and suggestions on turbotimers. Ive looked at HKS, and Greddy...any suggestions?
Old 04-26-2004, 10:33 PM
knucklebuster2 knucklebuster2 is offline
Is it a CD that you burned? Maybe the CD player isn't recognizing the CD if it was burned on a computer, or it may be dirty?
As far as maintenance, since you have over 100,000 on the car, try using a high mileage oil like Valvoline Max Life. Castrol and Quaker also make somethig like this. They contain more additives which will help protect the motor. It is a little more money per quart but worth it!
Old 04-26-2004, 11:10 PM
Re: advice
If you havent yet mobil 1 syntethic is the best. At least i think it is. Now that's alittle expensive. So pick which ever one u like.
Old 04-27-2004, 12:02 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: advice
i use 20-50 synthetic. change your timing belt and your water pump and get a basic tune up. you should be good then, this is just some advice from somone who was in your exact position just a year and a half ago. buying a used vehicle with high miles, best thing you can do is change the timing belt.
and as far as the turbo timer 1 min is good enough unless your at a track and your racing for half the day then you would need to put it on 3 min
Old 04-27-2004, 02:12 AM
vr4lover vr4lover is offline
Re: advice
CHECK THE TRANSFER CASE!!! i bought my vr-4 about a month and a half ago. i put in a new transfercase right after i bought it. (damn that "as is" clause) but anyways check to make sure that it is not leaking any oil. thats where mine failed. then after i put in that new one it was leaking oil. there was a problem at mitsubishi about the seals. so i got a free one and i think that one is leaking also.
Old 04-27-2004, 02:29 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Re: Re: advice
You did the transfer case under the recall notice didn't you?
Resistance Is Futile (If < 1ohm)
Old 04-27-2004, 08:03 PM
Hotshot8792 Hotshot8792 is offline
this is what i would do, i would start saving up, as you get to about 115K miles, i would replace the timing belt, waterpump, and oil pump. Then i would throw on a 20-40 dollar open element filter, a proboost mbc ($18), and an aftermarket boost gauge ($25), then gut your precats (if your not concerned about emissions). Practice your launches and you have a 12 second car.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-27-2004, 10:58 PM
Re: advice
Does anybody have links to how to gut your precats? I want to do it but i dont know how to, and do i have to worry about the O2 sensors?
Old 04-27-2004, 11:07 PM
CrimsonRacer's Avatar
CrimsonRacer CrimsonRacer is offline
Send a message via AIM to CrimsonRacer
Re: cd changer/turbo timer
[quote=mitsuGTvr4]O yea, one more thing. In the CD changer, which is the stock infinity one i think, i put 2 cd's in there, and hit the cd button on the radio, and it says disk one, but wont play...? anyhelpQUOTE]
Try flipping the CDs upside down with label facing down and tell me if it works.
Old 04-28-2004, 01:06 AM
Re: advice
CrimsonRacer
i was not aware that there was one! that sucks!
Old 04-28-2004, 09:08 AM
YogsVR4's Avatar
Re: Re: advice
CrimsonRacer
CrimsonRacer? That was me who said that....
Anyway -
You should go back to the dealership and get them to refund you're money for it (they bill Mitsubishi for recall work). They can verify that your car hasn't had its transfer case replaced before with Mitsubishi if you have your VIN number. Since its not on record there, they should be able to work something out with you.
Old 04-28-2004, 09:49 AM
Talking Cd Player!!!
yes, it finally works, thanks for that tip about flipping the cd..thats wut did it.
Old 04-28-2004, 03:34 PM
No problem, I remember having to figure that out the hard way.
