Old 04-26-2004, 08:09 PM
new2trucks new2trucks is offline
Send a message via Yahoo to new2trucks
Question 1985 F150 clutch
I can't push the clutch in far enough to allow me to change gears in my 85 F 150 without hitting the floor. how do I adjust the clutch.
Old 04-27-2004, 05:02 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 1985 F150 clutch
i believe you have a hydraulic clutch, theres no adjustment but it's probably low on fluid due to a leak somewhere. did you top off the reservior? make sure you take out the rubber piece before adding fluid. replace whats leaking and bleed the system, then it should work fine.
Old 04-27-2004, 01:12 PM
I was told it was a hydrolic clutch. I will try that thanks for the info. Most of the garages around here wont tell a woman anything exept bring it in and we will fix it.
Old 04-29-2004, 05:17 PM
worked out great thanks for the help
