Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 04-26-2004, 05:50 PM
bigfamei bigfamei is offline
engine doesn't start after replacing timing belt
Ok everyone i need some major help before i choke my roommate to death. I replaced my timing belt on my car, I have the two camshafts and the crankshaft aligned perfectly. but my compression test is coming back 71 psi and my car needs at least 119psi start what else am i missing? I am getting spark but i don't know where i'm going wrong It sound like it wants to start but it just doesn't any help would be great, and yes i do have a haynes repair book
Old 04-26-2004, 09:02 PM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
i would go back and check everything , make sure the crank is lined up on the intake stroke , you might have it 180 out
Old 04-27-2004, 09:17 AM
Re: engine doesn't start after replacing timing belt
but i know i have it correct according to the haynes book, intake is on the left and exhaust is on the right, and suppose to be aligned with the head the surface of the cylinder head and the timing marks behing the cams line up as well. but when you say they are 180 off should i put the timing marks at oppsoites ends of each other?
Old 04-27-2004, 12:24 PM
check the crank and make sure it is lined up in the right spot , it sounds like you have the cams in the right spot but the crank might not be in the right spot
Old 04-27-2004, 04:09 PM
checking the book it says the the timing mark should be on be 11 to 13 before the tdc. one the crankshaft i aligned the notch on the sprocket first then the timing mark on the pulley wheel is about 12 degree BTDC, man i'm stuck i don't know where the hell i'm messing up at, someone told me to check the tensioner but that seems to be fine
I'm frustrated
Old 04-27-2004, 08:42 PM
ask over at www.mazda626.net , i am sure someone over there can help you out , with out having the car in front of me it is just hard to say what the problem is
