View Poll Results: did i blow my engine
car wont start doesnt turn got oil light on died 0 0%
140,00 on 97 metro never changed timing belt 0 0%
Voters: 0. You may not vote on this poll
Old 04-26-2004, 05:25 PM
arturo38 arturo38 is offline
97 metro died
metro has 140,000 on it driving home got oil light on, lost power car died restarted it made a clunking sound went another 100 yards puttering died. no oil on dipstick didnt look behind me to see if there was any smoke with new battery ignition lights come on but doesnt turn.could it be belt or did i blow it.
Old 04-27-2004, 10:51 AM
geozukigti geozukigti is offline
Sounds like it's blown. Check the belt tho, you may have gotten lucky. If you run low enough on oil, the lifters won't pump up, and the car will die. You most likely spun a bearing, or fried the rings. If the belt is good, you're gonna need a rebuild.
Old 04-27-2004, 02:16 PM
Re: 97 metro died
thank you ill check the belt but my luck would require a rebuilt. is 325 reasonable for labor to have one installed.
Old 04-27-2004, 02:17 PM
Re: 97 metro died
thank you ill check the belt first
Old 04-27-2004, 05:56 PM
rruddfan21 rruddfan21 is offline
sounds like you blew the motor
Old 04-27-2004, 06:42 PM
325 isn't too bad on labor to have one put in. IF you know what you're doin, you can do it yourself in a weekend.
Old 04-28-2004, 05:21 PM
metro died
thank you for your response. ive ordered a engine with 56.000 on it should i replace the belt before installing it.
Old 04-28-2004, 06:54 PM
Always. Better safe than sorry.
