Go Back   Automotive Forums Car Chat > Ford > Contour
Old 04-26-2004, 04:49 PM
sirdeejay sirdeejay is offline
ignition off, engine still runs
We have had our 1996 contour for 4 years now. Over the weekend we got home, turned the car off, took the key out of the ignition and the engine was still running. Everything else on the car turns off, but the engine stays on. What could the problem be?
Old 12-13-2005, 10:37 AM
sblkcamaro70 sblkcamaro70 is offline
i know you posted this over a year ago damn near two years ago but just incase anyone is looking up this... my contour did the same thing. it ended up doing something with the windsheild wiper circuit. others i have heard the taillight was out... and a very common one i hear is the ignition switch is bad
Old 12-15-2005, 06:32 PM
rruddfan21 rruddfan21 is offline
Re: ignition off, engine still runs
possible that the ignition timing is too far advanced or there may be excessive carbon on ur pistons....
Old 12-15-2005, 08:43 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Re: ignition off, engine still runs
btw, this could be caused by a remote starter. Not sure if you have one, but it has been the culprit for others. This has been discussed on contour.org (along with every other question on here).
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 06-06-2006, 12:37 AM
Cheeseball Cheeseball is offline
Send a message via Yahoo to Cheeseball
also check the Spark plugs
Old 06-06-2006, 09:28 AM
carlos80 carlos80 is offline
the spark plugs have nothing to do with the engine still running they in no way produce their own spark. BTW this thread s a little old.
