Old 04-26-2004, 04:12 PM
Jdan1930 Jdan1930 is offline
Replaceing fuel pump 98 silverado z71
My fuel pump has went out on my 98 chevy z71 - I was wondering the easiest way to remove it. I was thinking about taking out the ft bed bolts and just loosen the rear and take a floor jack and lift the ft of the bed so I could reach the unit. Do you think this would work? ALSO, would i be better off to go back with a GM (AC Delco) pump over an aftermarket? Thanks any help would be most appreciated!!
Old 04-26-2004, 05:42 PM
michelq michelq is offline
Re: Replaceing fuel pump 98 silverado z71
if the bed bolt not rusted it is the easiest way to do it
and you said acdelco ,well yes for sure
Old 04-27-2004, 02:19 AM
buttnekked buttnekked is offline
from the files of been ther done that: be sure to support the bed with jack stands if you lift it. I had a s10 blazer body fall on my hand because I trusted a jack.
Old 04-27-2004, 03:01 AM
amac209 amac209 is offline
Send a message via MSN to amac209
is the tank almost empty? i changed mine yesterday by dropping the tank because i have a topper and big-ass tool box in the bed. wasn't the most fun thing i've ever done but not too bad just 2 bolts holding the tank up you have to unhook all that other stuff anyway and it's always smart to clean all the crap out of the tank when you change the pump. what i did was unhook the filler hose, vent hose and wires(made sure you get the ground wire too) then support the tank on a jack, remove the straps and lower it a bit and push it over to easily get at the pressure, return& vent hoses. then i had to jack up the truck to slide the tank out. i'd say this is an easy way to do it if you don't mind rolling around on the ground for while. just soak the shit out of the tank strap bolts with penetrating oil before removing them. oh yeah replace the inline fuel filter too. it took me about 2 hrs from start to finish.
have fun
Old 04-27-2004, 07:20 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I've done this both ways, and it was MUCH easier to lift the bed verses dropping the tank. I didn't even use a jack, I just had one of my friends help me lift the bed up a few inches and then we slid it back until we had easy access to the top of the fuel tank. Be careful not to scratch the bed when your movin it around..especially areas close to the bumper.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-27-2004, 03:13 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
I'd vote for unbolting the bed as well. We done this to a 1992 extended cab Z-71 about a year ago. 3 or 4 men can lift the bed off and then you hafe really easy access to the fuel tank.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
